All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Closed Thread   Post New Thread
Thread Tools Display Modes
  #1
Old 12-09-2005, 03:48 PM
terrakota terrakota is offline
Member
Default
can somebody explain to me what is negative voltage?, how a negative voltage is produced from a typical battery?, when and why you must use a negative voltage?.
can someboady drives me to a site with some usefull tutorial, guide, etc. explaining this?
thanks for an help
and please excuse my poor english
  #2
Old 12-10-2005, 06:11 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
Quote:
Originally posted by terrakota@Dec 9 2005, 10:48 AM
thanks for an help
When we measure voltages in a circuit, they are usually referenced to a common node in the circuit called "ground". Ground does not have to be connected to earth. It is just a term that indicates the common node in the circuit.
The schematic below should help explain this concept. As you can see, whether a voltage is positive or negative simply depends on which end of the battery (or other power supply) is connected to ground.
  #3
Old 12-10-2005, 08:51 PM
Member
Default
ok i understand but,
with a diode if you set the polarity of the battery to forward bias the diode you are applying negative voltage no? becasue the electros leave by the negative side.
if reverse polarity you are applying positive voltage to the reversed bias diode, so so, whats the difference?
thasnk for reply
  #4
Old 12-10-2005, 10:18 PM
Brandon Brandon is offline
Default
Forget about moving electrons because they teach you incorrectly to make it easier in the beginning. Electrons don't move, well, they do, but they move like 1 meter every 20 seconds in copper so its obviously not the electrons delivering the energy. You're looking to deep into this, its very basic.
BY CONVENTION, you assume current flows from + to - for all calculations. You also assume that current goes in the direction of the voltage drop. I.e. if point A is 3v and point B is 4v, since A is lower that B, the current would flow from B to A, the direction of the voltage drop. This also works with negative voltages. A is -4 B is -5. It would flow from A to B since B is lower than A.
Diodes (+) --[>|--- (-)
The polarity on diodes is used to tell you which way current will only typically flow in the diode in normal operation. It flows from the + to the - if you apply enough voltage to the + side such that the difference between the + and the - is atleast the diodes forward on voltage. Typically the ones u use in school n what not are 0.7 volts.
Remember, voltage is just a difference. It is that difference which forces current to flow and the current flows from the higher voltage to the lower voltage.
  #5
Old 12-10-2005, 10:28 PM
JoeJester's Avatar
JoeJester JoeJester is offline
Default
terrakota,
Look at the attached circuit. All the voltages are negative with respect to ground. Is the diode forward biased?
__________________
Joe
Navy Electricity and Electronics Training Series (NEETS) - pdf files - http://www.fcctests.com/neets/neets.htm
  #6
Old 12-10-2005, 11:13 PM
n9352527 n9352527 is offline
Default
Quote:
  #7
Old 12-11-2005, 12:40 PM
n9xv n9xv is offline
Default
Quote:
Originally posted by Brandon@Dec 10 2005, 06:18 PM
Forget about moving electrons because they teach you incorrectly to make it easier in the beginning.* Electrons don't move, well, they do, but they move like 1 meter every 20 seconds in copper so its obviously not the electrons delivering the energy.
Ok - I'am gonna have some fun with this just to warn ya!
FOR ILLUSTRATON ONLY!!! - KIDS DONT TRY THIS AT HOME!!!
Brandon, if electrons dont move - or - they only move at the incredibly slow pace of 1-meter / 20-seconds, then you should be able to plug an AC line cord into your 120-VAC outlet with the ends stripped and hold one in each of your (wet) hands. If what your saying holds, then you have some 20-seconds before you get "bit" by that all mighty force behind the fuse pannel!
Now, I have a feeling that you wont actually try this but - - - what might be stopping you?
M-M-M-M-m-m-m-m-m-m-m!
  #8
Old 12-11-2005, 01:18 PM
Default
"can somebody explain to me what is negative voltage?"
Any voltage can be negative with respect to a more positive point.
Example:
Take two 12-volt batteries, connect in series - negative terminal of one battery to the positive terminal of the other battery. Now, for purposes of reference and this explaination, drive a ground rod into the ground and connect the "tied end" of the batteries (negative-to-positive connection you made earlier) to the ground rod. The ground rod is the reference or common connection for our 12-volt battery arrangement.
So, if you measure between the ground rod and negative terminal of one battery (black lead to ground rod & red lead to negative terminal) you will read "- 12 volts". The voltage at this point is more negative with respect to ground. Conversely, you could say that ground is more positive with respect to that batteries negative terminal.
Electrons always flow from negative to positive. The positive-most point in any circuit represents a depletion of electrons and the negative-most point represents a surplus of electrons. The surplus (-) condition is always trying to satisfy or equilize the depleted (+) condition. Thus, electron current flow.
"Conventional current flow" depicts current flowing from positive to negative as a matter of conveinience. All is good and well as long as you realize that it is actually the movement of electrons doing the work.
"when and why you must use a negative voltage?."
The reasons are as varied as the circuits themselves. One common application of a negative voltage is for biasing circuits. A negative voltage may be used to turn a device on whereas a positive voltage may be used to turn it off and visc-versa.
BTW, JoeJester provides a good example for thinking "outside the box" - if you will.
  #9
Old 12-11-2005, 01:31 PM
Member
Default
Quote:
Originally posted by JoeJester@Dec 10 2005, 06:28 PM
terrakota,
yes its forward bias, well i think :-)
thanks to all for your help now i have a clearer image
  #10
Old 12-11-2005, 01:33 PM
JoeJester's Avatar
Default
One prime example of negative voltages is RADAR.
If you have a radar aboard a ship that uses a waveguide connected to the anode of the magnatron ... that waveguide is typically metal. The waveguide is attached to the bulkheads and overheads working it's way up the mast to the rotating antenna. Now, last time I checked, large ships were METAL so anything attached to the bulkheads, overheads, and masts were at the same potential as the ship itself [ground].
In order to have the anode of the magnatron at 20,000 volts, you must make the cathode negative 20,000 volts.
Another example is in your kitchen. A microwave oven. Again, the magnatron anode is at ground potential. You need to apply a large negative voltage to the cathode to get that magnatron to be forward biased.
There are times you want and need negative voltages. The a$$ you save maybe your own.
__________________
Joe
Tags
Related Site Pages
Section Title
Worksheet Junction field-effect transistors
Video Lecture Power Supplies - Applications - Diodes and Diode Circuits
Textbook Circuit components : Using The spice Circuit Simulation Program
Textbook Feedback : Bipolar Junction Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Clipper circuits : Diodes And Rectifiers
Textbook Introduction : Diodes And Rectifiers
Textbook The P-N junction : Solid-state Device Theory
Textbook Series batteries : Dc Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
L7812CV 12v Voltage Regulator Dropping Down To 3V gatekeeperamps General Electronics Chat 7 03-19-2013 07:53 PM
accelerometer negative voltage zacharoni16 General Electronics Chat 1 02-16-2013 10:37 PM
Negative Voltage Regulators PCBoy The Projects Forum 12 12-17-2011 06:24 PM
learning workings of inductor PG1995 General Electronics Chat 27 11-28-2011 02:58 PM
voltage dividers pilotnmech Homework Help 16 01-14-2008 02:30 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
