All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-04-2009, 03:04 AM
ferris_beuller ferris_beuller is offline
Default Treadmill Motor Speed Controller problems!
I have a treadmill where the motor-speed controller is going bad.
I was wondering what people think i should look at first. The symptoms are as follows:
power/controller board successfully continues to work as motor-speed increases. the motor-speed controller board's "SRC TRIG" LED keeps "blinking" and the motor keeps turning UNTIL about "2mph" is on the display. the motor just stops and the blinking LED dies out. 3 wires connect from the power/controller board, so can i assume its a pwm sigmal to control the 4-wire DC motor?
the LED's on the power/controller board still "blink" the same and the display goes down to "0mph" because the magnetic-reed switch for speed is now longer getting input--if i turn motor manually the display shows an "mph" of me activating the magnetic-reed switch..
i'm attaching a pic of the board... the IC's are (2) LM324N's and there are three T220 "D1..3" and two T220 "Q1..2" attached to the huge-heatsink.
I'm assuming a resistor broke down and the LM324's are not comparing the speed of the motor correctly. could it possibly be a bad DC motor's speed-sensor? I thought of opening up the DC motor, but i can't imagine that sensor going bad.... am i wrong? the "current limit" LED never turns on
any help please.... ?
  #2
Old 10-26-2009, 05:25 PM
trolley1 trolley1 is offline
Default MC-60 Motor Controller
Although this is an older post, I have just repaired this motor controller and as part of the process had to reverse engineer the circuit board to be able to troubleshoot. I intend to use the treadmill motor to run my lathe. A couple of years ago I used another treadmill motor to upgrade my old Delta drill press. Since I spent the time generating the schematics of these two motor controllers, I thought it would be worthwhile to post them so others might use them to troubleshoot problems. I am quite confident that they are not 100 percent accurate but close enough to do some good.
The Following 4 Users Say Thank You to trolley1 For This Useful Post:
fredsantizo (05-12-2013), MadCow405 (04-07-2010), Mudd (02-21-2010), tom66 (08-24-2010)
  #3
Old 01-14-2010, 01:46 PM
rickofmi rickofmi is offline
Default MC-60 Repair
Thanks for the hand drawn MC-60 schematic Trolly1. I have a fried SCR causing my treadmill to run full speed. I am replacing both with S4025L's that handle 5 more amps. Do you think I will have to modify the gate driver circuit? Reduce the 390 ohm resistors?
  #4
Old 01-15-2010, 11:47 PM
matador29b matador29b is offline
Thumbs up Thanks for the schematic trolley1
It was a great deal of help troubleshooting my board. It was not driving the motor at all. After testing and seeing all the signals, everything seemed to be working perfectly, but the scr's were not firing, so I assumed it was the opto-coupler. Turns out the "SCR FIRING" LED was not conducting enough current to turn the opto-coupler's LED ON, therefore not firing. Changing the LED fixed my problem! (The LED was actually lighting, for some reason not working the opto-coupler)
  #5
Old 01-18-2010, 03:11 AM
THE_RB's Avatar
THE_RB THE_RB is offline
Default
It's probably the optocoupler "ageing" and a typical symptom of an opto on the way out is the need to drive it with slightly higher currents.
It might have just been the LED, but I wouldn't be surprised if you soon have to change the opto too.
__________________
Roman Black - PICs and electronics. Author of BTc PIC-sound encoder, Shift1-LCD project, the TalkBotBrain talking PIC controller, LiniStepper open-source microstepping motor driver, the Black Regulator 2-transistor SMPS, and probably some other stuff; www.RomanBlack.com
  #6
Old 01-19-2010, 11:38 PM
Default
Quote:
I haven't been logged on for a while. I would guess that you would not have to modify the gate driver circuit. You could compare the gate triggering requirements of your SCR with those of the original.
  #7
Old 01-19-2010, 11:48 PM
Default
Those are exactly the problems that I found when I repaired my MC-60. Had to replace the LED and the opto-triac.
  #8
Old 02-01-2010, 03:57 PM
devnull03 devnull03 is offline
Default Fast Recovery Diode Keeps Blowing
My Horizon T30 treadmill has been through four motor control boards and each time it blows the Fast Recovery Diode that is in series to the motor. Last time, I replace it with a much higher-rated one but the motor still doesn't move. Any ideas there?
Thanks!
  #9
Old 02-06-2010, 05:46 AM
tvmanjon tvmanjon is offline
Default
Ive struggled with a MC 60 that the motor wont run and the SCR Trig LED wont light. Outputs,caps,all solid state items check good.Ive replaced both LM324s, MC3052 and the SCRs went and replaced all caps with no luck. I dont like shotgunning a repair but was stumped. I swiped a LED from another controller and still no luck. What am I missing. How do you test a LED and what is a sutable replacement?
  #10
Old 02-08-2010, 07:13 PM
Default
If you have access to an oscilloscope then you can trace the SCR trigger pulses. Testing a LED in-circuit may be tricky. You could lift the non-grounded lead and apply voltage thru a resistor. Basically the circuit is applying 12 volts thru a 510 ohm resistor so you could clip in a similar sized resistor directly from the 12 volt supply and see if the LED lights. Check to make sure the 12 volt is proper with a meter. Alternatively you could temporarily short out the SCR Trig LED and see if the motor works. It is not essential to make the SCRs fire but if open they won't.
Tags
Related Site Pages
Section Title
Worksheet Servo motor systems
Worksheet Bipolar junction transistors as switches
Worksheet AC motor theory
Worksheet AC generator theory
Textbook Tesla polyphase induction motors : Ac Motors
Worksheet Step-up, step-down, and isolation transformers
Textbook Reluctance motor : Ac Motors
Textbook Synchronous Motors : Ac Motors
Worksheet DC motor control circuits
Worksheet DC motor theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Needed help with H-Bridge motor controller designeer The Projects Forum 13 05-29-2011 04:00 AM
PWM Controller for giant antique 20+ HP DC motors? DMahalko The Projects Forum 7 10-27-2008 11:53 PM
Ethernet controller interface with microcontroller diyora Embedded Systems and Microcontrollers 1 01-22-2008 08:24 AM
Nintendo GBA as controller BlackBox Embedded Systems and Microcontrollers 0 04-22-2007 02:06 PM
Strobe light and light controller problem FlyBriz The Projects Forum 3 10-12-2006 08:51 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
