Little background real quickly. I'm building a custom computer desk, everything will be mounted in the desk, all computer components, monitors, speakers, etc.
I'm designing the panel before I start the desk, so I know how much space I need on the location where the led panel will be mounted at.
I'm going to use 48 red, 48 green, and 48 blue pre-wired LED's with resistors, for 144 led's in total.
I going to build a led panel, with 3 potentiometers, so I can control the output of each color, RGB, so I can mix the colors, for whatever 100K's different color mixes, in theory anyways.
I would like to use the 12V outputs from one of the two power supplies that I will be using to power the computer and other components, though I have a feeling that the power supply may not be able to supply enough voltage and/or current to power the panel.
Power Supply Specs:
AC Input: 115V
DC output:
+3.3v - 24A
+5v - 28A
+12v - 70A
-12v - .08A
+5VSB - 3A
1000W max combined output
Specs located here:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?Sku=ULT40064
If someone doesn't think the power supply will work, just let me know, and I will be more than happy to change it to some other way, if you have another idea on how to power the circuit.
I have 4 banks with 36 led's per bank. Each bank has 3 rows of 12 led's per row. Each row will be wired in parallel, and each strip will be wired in series. Shown in attachments.
What I'm worried about is with all the resistors, some led's will be bright, and some will be dim. Though with me wiring them in parallel and then series they shouldn't dim (too much).
I'm going to use these pre wired led's with resistors, from here...
Blue LED: http://www.besthongkong.com/product_info.php?cPath=13_16&products_id=185
Red LED: http://www.besthongkong.com/product_info.php?cPath=13_16&products_id=147
Green LED: http://www.besthongkong.com/product_info.php?cPath=13_16&products_id=148
The values of the resistors are...
blue and green is 470Ω
red is 560Ω
(I can have them customized to whatever value I need, so that's good to know).
I need to make sure that I have the potentiometer wired correctly, I haven't wired on in forever, so I'm a little rusty at best.
What should I use for the resistor values? I'm thinking that 560Ω, is a little too much, so I'm thinking about 120-240Ω for all resistors.
And should I use any voltage regulators, or similar, even though the power supply is producing 12V, give or take?
Power Supply Specs:
AC Input: 115V
DC output:
+3.3v - 24A
+5v - 28A
+12v - 70A
-12v - .08A
+5VSB - 3A
Specs located here:
red is 560Ω
