All About Circuits Forum
Go Back   All About Circuits Forum > All About Circuits Commmunity Forums > Off-Topic
Notices
Off-Topic A place to discuss anything other than electronics with other members. General conversation allowed, but please have consideration for your fellow members.
Closed Thread   Post New Thread
Thread Tools Display Modes
  #1
Old 02-02-2009, 05:31 PM
Farlander's Avatar
Farlander Farlander is offline
Default MOLECULAR RESONANCE OF LIQUID H20
Hi People,
Wasn't sure where to post this so here we are. I'm trying to dissociate water molecules by using high voltage and/or mechanical vibration at the molecular resonant frequency of water. I'm going to assume for the sake of simplicity the gap between the electrodes will be 1mm.
You can see the graph showing the absorption spectrum. Absorption equates to greater bending of the molecule. This is copied from this page http://www.lsbu.ac.uk/water/vibrat.html . I don't understand what is cm^-1? What is wave number? Can we use this information to extrapolate the proper pulse frequency?
  #2
Old 02-02-2009, 06:10 PM
KL7AJ KL7AJ is offline
E-book Developer
Default
Quote:
Originally Posted by Farlander View Post
Hi People,
I'm pretty sure the molecular resonance has little to do with how easy it is to dissociate water. If such were the case, microwave ovens would dissociate water all the time, which we know doesn't happen.
D.C. voltage is as effective as anything for dissociating water.
eric
__________________
REAL men don't need voltmeters.
  #3
Old 02-02-2009, 06:53 PM
Farlander's Avatar
Default
KL7AJ-
I respectfully disagree. True, microwaves agitate the water molecules, causing increasing temperature
Voltage fields around water align the dipolar molecule.
So, when the molecule is at it's greatest "flexed" position, or "bent" or "squished" whatever, it is elongated, and the electron bonds are weaker. At this instant it should be A LOT easier to separate the water with voltage.
  #4
Old 02-02-2009, 07:30 PM
jpanhalt jpanhalt is offline
E-book Developer
Default
Do you have any idea to what frequencies those wavenumbers correspond? You will need something better than a CMOS 555 for your oscillator.
Metaphysics might be a better forum on which to post this project.
John
  #5
Old 02-02-2009, 07:34 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
The molecular ressonant frequency of water is in the near-infrared. The absorption spectrum has nothing to do with "bending" the molecules.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #6
Old 02-02-2009, 10:07 PM
triggernum5 triggernum5 is offline
Default
Its a common talking point with the whole HHO generator crowd.. Some ppl have claimed that microwave/IR excitation makes electrolysis energy feasible for HHO production.. (Obviously I've never seen this successfully demonstrated..
Anyways, the wavenumber, or cm^-1 means wavelengths per cm..
the wavength would be (1/wavenumber)cm.. So your graph is ranged from 2.5-3.0microns, or 5-6x the size of visible light waves..
  #7
Old 02-02-2009, 10:26 PM
Farlander's Avatar
Default
COOL
I learn so much awesome stuff here...
My point about absorption is that maximum absorption occurs at resonance. Absorption is literally transferring energy into physical motion of the molecules. In the case of water, being it's a triangular bond, the molecule is actually getting squeezed like a thigh master. When it's squeezed all the way, its elongated, and the bond is weakened. I recently read about someone using a quartz transducer as the cell container to facilitate this kind of resonance, and then using HV electrodes housed in the container to break the bonds.
  #8
Old 02-02-2009, 10:38 PM
AliceT
Guest
Posts: n/a
Default
Why doesn't someone just come out and answer the question? The frequency is of the order of 100 TeraHz, or 100,000 GigaHz, or 100,000,000 MegaHz, or 100,000,000,000 kiloHz or 100,000,000,000,000 Hz.
In other words, an infrared laser is what you need. Of course, it's not going to work, but try if you want. But be careful because 3 microns is safe for the retina of the eye, but can damage the cornea since the radiation is absorbed so well that the thin layer of water takes all the energy. - OUCH! Buy the proper laser safety glasses, ... and some tissues so you can cry when you realize you wasted your time and money.
  #9
Old 02-02-2009, 11:06 PM
Farlander's Avatar
Default
Ouch so harsh, but thank you for the answer.
Interesting that you should metion lasers because that's exactly what Meyers incorporated into his last system. The cell electrodes had slots cut in them for laser light to "prime" the water.
  #10
Old 02-02-2009, 11:42 PM
Default
Theres still those dang laws of thermodynamics to overcome.. Electrolysis of water for HHO just isn't a feasible energy source.. Its like buying new cars and hoping to make money reselling them..
Tags
Related Site Pages
Section Title
Textbook Switch types : Switches
Worksheet Electrical conduction in semiconductors
Worksheet Fundamentals of radio communication
Textbook Microwave tubes : Electron Tubes
Worksheet Resonance
Textbook Frequency and phase measurement : Ac Metering Circuits
Textbook Resonant filters : Filters
Textbook Resonance in series-parallel circuits : Resonance
Textbook Valence and Crystal structure : Solid-state Device Theory
Textbook Electron activity in chemical reactions : Batteries And Power Systems
Similar Threads
Thread Thread Starter Forum Replies Last Post
Water molecular resonance beenthere Off-Topic 10 11-22-2012 01:30 PM
Resonance Question! paul9619 Homework Help 2 01-04-2010 07:23 PM
R-LC Parallel and series resonance Rubberfrog General Electronics Chat 23 12-24-2008 12:36 AM
Stepper Motor Resonance (Nat'l Freq) werlidm The Projects Forum 2 07-22-2007 10:44 PM
Anti resonance in parallel A.C circuits circuit2000 Homework Help 4 02-08-2007 05:47 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
