my problem is that i'm using two voltage dividers in a circuit ..... both r getting effected by each other.... is there any way that i could isolate them from each other..... i've explained the matter in a better way in the image.....
the frequency of the square wave is 300bps.....
plz help....and keep it as simple as possible and briefly explain the solution too..... thanks
problem 2:
at some other place i've a 300bps square wave which has 2.5V as lo and 3V as hi..... i want to change it to a 0-5 square wave..... how would i achieve this???? i thought of achieving it in two steps... first bring the lo voltage back to 0V, like remove the DC component and then amplify it to 5V using a single supply op amp...... plz comment if there is a better solution.....
problem 2:
