All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-27-2009, 08:38 AM
Turk Turk is offline
Default Control Circuit for an Overhead Crane
Good Morning All
im struggling with a piece of homework set by my tutor .
He requires me to come up with a control circuit for an overhead crane , that will have the following criteria.
Forward/reverse
Up/Down
Left/right
must have LIMITS
must work of a remote station .
Ant ideas are appriciated thanks ALL.
  #2
Old 01-27-2009, 11:00 AM
kubeek's Avatar
kubeek kubeek is offline
Default
I think you just need to find a diagram of single motor control with limit switches, and apply it to all the three motors you need to control.
Remote location is just longer wires to the control buttons.
  #3
Old 01-27-2009, 01:33 PM
KMoffett KMoffett is offline
Default
Quote:
Can this be a "wired" remote, such as a 6-button pendent on the end of a cable running to the cranes power/motor/control box?
Ken
  #4
Old 01-27-2009, 02:01 PM
Default
Yes m8 ..
  #5
Old 01-27-2009, 02:29 PM
Default
Can we assume that these are small DC motors, as you would use in a model crane? For this type of motor's on/off/direction control look into "H-bridges", either solid-state or electro-mechanical relay.
Ken
  #6
Old 01-27-2009, 03:45 PM
Default
I think its all factory sort of cranes
we have been working alot on circuits in the class, how to start a motor in star an switch to delta that sort of thing , im stuggling as to were to put the limit cut off .
  #7
Old 01-27-2009, 03:50 PM
Default
Sorry Turk, you're into big, high HP, multi-phase motor control. That's out of my area of expertise (if I can even say I "have" expertise. ) But, I'll be watching.
Good luck.
Ken
  #8
Old 01-27-2009, 07:53 PM
kubeek's Avatar
Default
First you need to get the general idea how to start & reverse.
As far as I remember, three-phase motors are reversed by swapping two of the three phase wires, but donīt take this for granted as I donīt know the exact type of your motors.
You should end up with some diagram, where you have two tri-phase relays, one for forward and one for backward motion. Then you need some circuit to control the two relays and take the limit switches into account.
Limit switches should be closed when not reached, so you can wire the limit switch in one direction in series with the relay moving the motor that way, so it disconnects the relay when reached.
You also need to make some protection so that you cannot activate both relays at once or it would short the main AC. You can do this by using DPDT switch so that one half activates one relay, and the other half disables the other one. (again using the NC contact in series with the other relay) This way when you push both, none of the realys gets activated.
So in total, you should need only 2 power relays, and two DPDT switches to control one motor with end limits.
btw, is this making any sense to you?
Tags
Related Site Pages
Section Title
Worksheet Encoders and decoders
Worksheet Basic electromagnetism and electromagnetic induction
Similar Threads
Thread Thread Starter Forum Replies Last Post
Total Resistence in Parallel circuit AWSariti General Electronics Chat 14 02-27-2009 11:44 AM
LOW VOLTAGE Circuit TESTER lamps relicmarks General Electronics Chat 5 11-03-2008 12:32 AM
Automatic Light Circuit For My Car tonysticks General Electronics Chat 16 06-26-2008 07:29 PM
I Need A Circuit to Control The Frequency And.... Wassouflover The Projects Forum 2 04-09-2008 06:21 PM
the term "common" shelly50 General Electronics Chat 27 01-23-2006 04:02 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
