All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-18-2009, 10:09 AM
Lieta Lieta is offline
Junior Member
Default Twin T Bandpass Filter transfer function's derivation
Hi, guys.
Could somebody help me out with the subject? I've searched the net, but didn't find anything useful.
Link to circuit: http://www-k.ext.ti.com/SRVS/Data/ti...s/spttbphq.gif
  #2
Old 01-18-2009, 10:15 AM
bertus's Avatar
bertus bertus is online now
Super Moderator
Default
Take a look at the PDF in the link.
http://www.drp.fmph.uniba.sk/ESM/twin.pdf
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 01-18-2009, 10:18 AM
mik3's Avatar
mik3 mik3 is offline
Default
Assume an ideal op amp so you can say that the voltage on the non-inverting terminal (V2) equals the voltage on the inverting terminal (V1). The voltage are measured with respect to ground. First find the transfer function (relationship) between Vin and V2. Then find the transfer function between Vo and V1. Finally, because V1=V2, substitute V1 with the equation relating V2 with Vin to get the transfer function between Vo and Vin.
  #4
Old 01-18-2009, 10:38 AM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
Quote:
Originally Posted by Lieta View Post
Hi, guys.
What do you need to know about this circuit topology?
hgmjr
  #5
Old 01-18-2009, 02:53 PM
The Electrician The Electrician is offline
Default
Quote:
hgmjr
Judging from the subject line, I think he wants you to produce one of those lovely detailed transfer function derivations that you do so well. :-)
But, he hasn't shown any of his own work yet.
  #6
Old 05-01-2009, 05:49 PM
Junior Member
Default
Thanks, bertus, for the document. The twin-T filter without an op-amp is a band-stop filter (see fig. 4).
Denote
Vout - output of whle circuit.
Vin_pas - input of passive twin-T filter
V(-) - input of inverting input of op-amp.
V(+) - input of non-inverting input of op-amp
Vin - input of the whole circuit
Vin_pas = V(-) = V (+) = Vin*k, where k = R5/(R4+R5).
Vout/Vin_pas - band-stop filter transfer funct. and because Vin_pas = Vin*k,
Vout/Vin also band-stop filter transfer funct., but actually the circuit if band-pass filter. How to take an op-amp into account? Where am I wrong?
  #7
Old 05-02-2009, 01:44 AM
Default
Are you still interested in deriving the overall transfer function for the opamp plus twin-T feedback network?
Are you required to use any particular method to derive it, or can you use any method you like?
This thread is several months old, so I thought I would ask if your interest level is still high.
  #8
Old 05-02-2009, 09:18 AM
Junior Member
Default
I'm still very interested in deriving the overall transfer function for the opamp plus twin-T feedback network. Any method is fine.
  #9
Old 05-02-2009, 11:43 AM
Default
You said "How to take an op-amp into account?". Does this mean that you don't want to make the usual assumption that the opamp is ideal, with infinite gain?
  #10
Old 05-02-2009, 11:48 AM
Junior Member
Default
No, assume op-amp as ideal. I ment how to derive transfer function for whole circuit, including op-amp, because without op-amp it's a notch filter, but with it it's band pass filter.
Tags
Related Site Pages
Section Title
Worksheet Active filters
Worksheet Passive filter circuits
Textbook Resonant filters : Filters
Textbook Band-stop filters : Filters
Textbook Band-pass filters : Filters
Video Lecture Op Amp Applications - Band-Pass & Band-Stop Filters - Op Amps and Op Amp Circuits
Textbook The common-base amplifier : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tunable bandpass filter MikeD_72 General Electronics Chat 10 05-08-2009 09:58 PM
Bandpass filter help sjkim0329 Homework Help 9 10-20-2008 03:31 PM
square wave -->sine using passive bandpass filter windell747 General Electronics Chat 2 06-22-2008 08:00 AM
Bandpass filter diwa2000@gmail.com General Electronics Chat 3 06-13-2008 02:35 PM
What is the transfer function of this LC low-pass filter? zhaojia General Electronics Chat 7 11-25-2007 02:27 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
