All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-13-2009, 09:52 AM
shahnawaz shahnawaz is offline
Junior Member
Post neutral to earth voltage
hi dear all
can any one recommend me how much voltage should be enough between neutral to earth(ground) bars for a smooth running of a system.
and one more thing is what the standered of world for the voltage between earth(ground) to nutral. and how much resistance is acceptable for the earth grounding. thanks for a quick reply.
  #2
Old 01-13-2009, 09:58 AM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
This is a tricky subject, in more than one way. Here is the problem.
If you have a leg with 10 amps running through it, and the length of wire is dropping 3 volts, then there will be 3 volts between earth and neutral at the socket where power is tapped. Where the two connect (usually the line pole) there is no difference. So even though they are the same wire there can be a voltage differential, because the wire is also a resistor.
There is no standard for this voltage as far as I know, just whether the wire itself is safe to carry the full current load. If it meets the criteria then the voltage difference between earth and ground doesn't matter.
As to the second part of your question I don't know the definitive answer. As far as I know it is a 6 foot spike into the ground for ground.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #3
Old 01-14-2009, 05:29 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
The NEC, article 250.56, specifies no more than 25 Ohms to Earth ground. Voltage would, per this code article and Ohm's Law, be current times 25.
If the NEC does not apply in your area, I suggest contacting your local authority for requirements. If the NED does apply in your area, I suggest contacting your local authority for any local variances or exceptions.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #4
Old 01-14-2009, 04:23 PM
italo italo is offline
Banned
Default
Lets see ground wet ground or sand ground. Both are not exactly equal.
Tags
Related Site Pages
Section Title
Textbook Shock current path : Electrical Safety
Worksheet Electrical noise and interference
Worksheet Basic oscilloscope operation
Textbook Single-phase power systems : Polyphase Ac Circuits
Textbook ElectroStatic Discharge : Practical Analog Semiconductor Circuits
Worksheet Safety grounding
Worksheet Elementary circuits
Worksheet Voltage, Current, and Resistance
Textbook Electrical signal types : Digital Communication
Textbook Safe circuit design : Electrical Safety
Similar Threads
Thread Thread Starter Forum Replies Last Post
Volume III - Semiconductors Zener diodes - few corrections needed chindu Feedback and Suggestions 1 10-31-2008 09:54 AM
neutral and earth h.d General Electronics Chat 5 08-11-2008 02:15 PM
Treatise about Voltage Ratch Physics 100 05-18-2008 07:55 AM
voltage dividers pilotnmech Homework Help 16 01-14-2008 02:30 PM
fields alphaone Physics 4 12-23-2005 06:03 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
