Ok, I have been reading about diodes. I was wondering if this would work.
Say I cut one end of a wire and say that one end of a wire can be pluged into the wall. If I but a diode that is strong enough to hold 120volts back.
Can I charge a DC battery.
For Example I want to plug a plug into the wall and run it to a car battery.
Is it like
|----------------diode----- aligator clamps --- dc car battery
When I split the wire can I use any of the 2 wires to connect the diode ?
120 volts is the voltage of my house at 60 hz so when I convert it to DC
what is the voltage ? I would think it would vary from 0 to 120 over the 1/60 of a second?
Is it like
