Hello all,
I am new here, looking for some help on a project I am working on. I am building an array of 16 color changing LED's.
Specs on the LED's: http://www.superbrightleds.com/specs/rgb-acc-spec.htm
The forward voltage is listed as 3.8V-4.5V. I'm assuming that this varies with the color produced? Anyway, I am trying to determine a safe voltage value to use in calculating what resistors I am going to need. I'm either going to use one resistor for each LED, or one resistor per 2 LED's. My design current is 20mA, and input voltage will be 6V from 4 "AAA" batteries. The circuit is parallel.
Can anyone help me? Thanks...
