All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-04-2009, 04:08 PM
dolphi dolphi is offline
Unhappy Need circuit explanation for heat sensor, automatic fan cooling..
Hi all...
To start wid, am just a beginner and i cant figure out a neat and well defined explanation for the circuit.. Pls guys help me in giving an explanation so tat even a non-electronic student also can understand... I specifically want to know how the relay circuit works from the time the dc voltage s given and after the op-amp compares the voltages and gives signal to the base of the transistor and the signal s obtained across the collector terminal... tat s wen the relay opens and how...
Pls help guys......
  #2
Old 01-04-2009, 04:19 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Why don't you start out by reading the page where the schematic came from:
http://www.uoguelph.ca/~antoon/circ/auto-fan.html
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #3
Old 01-04-2009, 04:23 PM
mik3's Avatar
mik3 mik3 is offline
Default
Say them that the transistor acts a switch. When the voltage on its base it greater than 0.7 it closes, otherwise it is open. When the switch (transistor is off) is open the no current flows and thus the relay is off. When the switch is closed (transistor is on) current flows and the relay is on.
Another easy way is by resistance terms. Transistor off-high resistance-relay off, transistor on-low resistance-relay on.
That is how students can understand it easily even if the operation of the transistor is not actually like that.
  #4
Old 01-04-2009, 04:33 PM
Default
Thanks yaar... But i need the relay operation... tat s how the relay s positioned (i mean the contacts of the relay) before the 12 v s applied and after it s applied and then after the transistor s turned on....
  #5
Old 01-04-2009, 04:37 PM
mik3's Avatar
Default
When no voltage is applied to the relay coil a spring holds one of the contacts (moving contact) away from the other. When voltage is applied across the relay's coil a magnetic field is created and it pulls the moving contact until it touches the other contact.
Have a look here:
http://www.howstuffworks.com/relay.htm
  #6
Old 01-04-2009, 04:47 PM
Default
Wont tat 12v dc voltage v apply to the circuit hav any effect on the relay..? s tat coz of the diode tat s present..? S tat so tat only the voltage at the collector terminal turns on the relay..?
  #7
Old 01-04-2009, 04:57 PM
mik3's Avatar
Default
The diode is there to protect the rest of the circuit from the back EMF the coil of the relay when it is turned off.
When the transistor is off the bottom side of the relay coil is at 12V. Because the top side is also at 12V there is no voltage drop across the relay coil and thus is off.
When the transistor is on the bottom of the relay coil is almost at zero volts. Because the top side is at 12V the voltage across the relay coil is almost 12V. Thus the relay turns on.
  #8
Old 01-04-2009, 05:16 PM
Default
Thanx a lot....
  #9
Old 01-04-2009, 05:26 PM
mik3's Avatar
Default
You are welcome
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Protective relay circuits
Worksheet Flip-flop circuits
Worksheet Latch circuits
Worksheet Open-loop opamp circuits
Worksheet AC motor control circuits
Worksheet Oscilloscope trigger controls
Worksheet Batteries
Video Lecture Hardware: clock, µP, chipset - Microprocessors
Textbook Time-delay relays : Electromechanical Relays
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help with television cooling fan blaubne General Electronics Chat 4 12-27-2008 05:30 PM
help : transmitter circuit explanation t-bone The Projects Forum 3 04-06-2008 01:31 AM
Cooling fan connection on a tv set Silva Computing and Networks 5 12-18-2007 11:01 PM
Learning - project pwm MrWoo The Projects Forum 5 06-19-2007 07:47 PM
the term "common" shelly50 General Electronics Chat 27 01-23-2006 04:02 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
