I am using a Kill A Watt EZ meter to measure the power needs of a pellet stove.
It is brand new. I measured the start, and after. Its needs include an igniter for about 8 minutes, a feed auger, a combustion blower and a convection blower.
I had the meter on watts. I was pleased to see it was about half the draw I thought it would be. Start was about 360, ( igniter is a watt hog) but when the igniter went off and it settled in
to the 2 blowers and the occasional auger motor feed, it was about 150 watts.
I thought it was excellent and I could indeed run this off a battery bank for a couple days easy.
I then switched it to VA and it said about 280. I switched it to amps and it said 2.6 amps.
So what is the real story. The factory specs do say that it requires about 300 watts to run
without the igniter.
I was hoping they were wrong. Why is VA and the amp so much different than the watts
reading.???
The manual for the meter says amps are displayed in true RMS...
watts are displayed in active power watts.....
VA is displayed in apparent power VA....
whats the story????
thanks
reading.???
whats the story????
thanks
