All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-26-2008, 06:17 PM
Khalid Abur-Rahman Khalid Abur-Rahman is offline
Junior Member
Default DC and AC load line equations?
Can someone explain to me step by step how to plot and make transistor characteristics curves...? How do I go about drawing load lines and stuff?
R the many different lines on their for different values of rb?
  #2
Old 12-28-2008, 08:47 PM
Thevenin's Planet Thevenin's Planet is offline
Send a message via Yahoo to Thevenin's Planet
Default Plot load line,Dc/AC?
ploting a load line for a D.C. bias is lort of finding the D.C. Beta. Make a circuit in which you can vary the Base and the collector.Pick sone inteval (i.e. 1volt,2volt,3 volt,ect).As you move from volt to volt the collector voltage should not alter from some selective voltage when measuring the
base current and collector voltage and current.If the collector voltage changes adjust it through a "Pot" in the collector circuit.Continue the sequence until you have reached or almost reached the breakdown point on Base emitter.Once reaching the point adjust the Vcc to an higher voltage (for instance 2 volts) continue this process until the breakdown point is close.Every meadurement have to recorded.Once completed then the graph can be hand drawn.
A.C is smillar, but using a frquency of some sort.There is a device the can be use but you must have a ocilliscope which same a lot of restless time.
  #3
Old 12-28-2008, 11:09 PM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
Here is a link to an article on bipolar junction transistors that has a short section on AC and DC load line analysis.
Check out Figure 4-34.
hgmjr
  #4
Old 12-29-2008, 12:32 AM
Audioguru Audioguru is offline
Banned
Default
I plotted load lines for transistors in school. Then I made circuits and the transistors didn't perform like the load lines. The transistors caused severe distortion when the levels were fairly high. A simulator shows the severe distortion like this:
  #5
Old 12-30-2008, 08:02 PM
Default ac/DC load line
Hi again!
I have this assumption that says that most mathematical formulas are only a approximation of the results,or a reminder regarding something important about subject. It save a large amount of trial and error. So that some small ajustment have to done to the finished product. There are does characteristics within the material or circuit that are not placed in the formulae.I have notice this in various calculations dealing with electronic equations. There is a very informable article in the electronic funamental 2 about DC/ac load line. ac load line analysis.I always would remember from high school that arithmetic is very exact.
To stand on the shoulder of others one must know what they know to reach farther.
  #6
Old 12-30-2008, 09:11 PM
hgmjr's Avatar
Super Moderator
Default
Quote:
Originally Posted by Thevenin's Planet View Post
Hi again!
Can you indicate which electronic formula you believe to be an approximation?
hgmjr
__________________
"No human being should be allowed to have this much fun."
hgmjr
May we never lose compassion for those who need our help and encouragement.
  #7
Old 12-30-2008, 09:19 PM
hobbyist hobbyist is offline
Default
In electronics, formulas are almost always approximations, due to component tolerances, as well as other factors. You use the formulas to get you in the ballpark but it's the actual prototyping of a circuit that gets you the exact results.
Tags
Related Site Pages
Section Title
Worksheet JFET amplifiers
Worksheet Class A BJT amplifiers
Worksheet Bipolar junction transistors in active mode
Worksheet Simultaneous equations for circuit analysis
Worksheet Th'evenin's, Norton's, and Maximum Power Transfer theorems
Textbook ``Long'' and ``short'' transmission lines : Transmission Lines
Worksheet Resonance
Worksheet Time constant calculations
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Active mode operation : Bipolar Junction Transistors
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
