All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-17-2008, 02:11 PM
garry.owens garry.owens is offline
Junior Member
Default op amp based frequency to voltage conversion
i am at the moment trying to work on a signal gen and i am trying to keep the cost to a min so i am looking to convert frequency to voltage so that i may use a volt meter insted of a frequency counter in my project dose any one know of a circuit that doese this using a op amp or simular as i have several op amps in my box thank you
  #2
Old 12-17-2008, 03:59 PM
beenthere's Avatar
beenthere beenthere is offline
Default
Look into an LM2907. It's a specialized IC that does F tp V conversion.
If you have an accurate time base, it is also pretty simple to use some counter IC's to make a frequency counter. That is much more accurate than the frequency to voltage conversion.
__________________
First comes the hardware, then the software.
  #3
Old 12-17-2008, 04:31 PM
Junior Member
Default
this i know althow i have not used modern frequency chips and admid am a little aprehensive at some of them the reson that i was thinking of a 741 is that i have several of these in my spares box and was hoping to save some cash thank you for taking the troble to answer and if i get nothing else i will have to go down this rout althou i would rather not as cash flow at the moment is to say the least tight gasser
  #4
Old 12-17-2008, 05:16 PM
bertus's Avatar
bertus bertus is offline
Administrator
Default
An frequency to voltage converter can be made with an monostabile multivibrator like a 555, followed by an intergrator wich can be made with the old 741.
What happens ia as followed :
You make pulses of equal width.
The higher the frequency the higher the number of pulses.
By intergrating them you get a voltage dependend on the number of pulses.
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #5
Old 12-17-2008, 10:37 PM
studiot's Avatar
studiot studiot is online now
E-book Developer
Default
Quote:
signal gen
What sort of sig gen?
All the solutions quoted so far a pretty low frequency.
What means do you have to calibrate?
Integrating current is better than integrating voltage. the following will give you a reasonably linear four range frequency scale, to 100Khz.
  #6
Old 12-18-2008, 07:56 PM
Junior Member
Default
this is just audio frequency up to a max of 20KHZ an i will be using the ocuilascope to callabrait thangk you all for youre quick replys the sig gen i am using is a pic programed unit
  #7
Old 12-19-2008, 12:46 AM
kahafeez kahafeez is offline
Default
hi just to add my part..... i did this earlier..... it was BFSK demodulation.... the principle is same..... u've to detect the freq and convert it into high or low amplitude.... i used PLL.... there is this ic called NE565 or LM565(both are same)..... it can detect upto 500KHz..... and its cheap too.... and it should be accurate as it is a coherent detector....
  #8
Old 12-19-2008, 08:29 AM
bertus's Avatar
Administrator
Default
When you use a 555 that makes pulses of about 40 μSeconds,
you could measure upto 25 kHz.
The lowest frequency is depending on the intergrator,
as it will fluctuate more at lower frequencies.
Greetings,
Bertus
PS mind you typing, it looks rather odd and does make it more difficult to understand.
__________________
  #9
Old 12-20-2008, 09:12 AM
Junior Member
Default
thank you all for you're help i do apologise for the typos but im not a keyboard person but i will take more care in the future
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
principles of frequency to voltage converter blue6x General Electronics Chat 20 06-09-2011 04:48 AM
Current to voltage conversion schnnegi The Projects Forum 1 11-08-2008 06:06 AM
voltage dividers pilotnmech Homework Help 16 01-14-2008 02:30 PM
Resistance to voltage conversion circuit EightequalsD General Electronics Chat 1 08-08-2005 08:41 PM
voltage vs. frequency ledjr Homework Help 3 11-26-2004 02:08 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
