All About Circuits Forum
Go Back   All About Circuits Forum > Abstract Forums > Physics
Notices
Physics Discussion forum for anything physics related.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-18-2005, 07:50 PM
friendforall123 friendforall123 is offline
Default
I have circuit with a voltage source having equation E = 20*sin(15*t).
It has two resistances (R1, R2), one capacitor © and one inductor (L).
C is in parallel with R2 and L (which are both in series).
the above ciruit is in series with R1.
this gives us two governing equations:
E = I1*R1 + (1/C) * ∫ (I1-I2) dt
and
I2*R2 + L (dI2 / dt) + (1/C) * ∫ (I1-I2) dt = 0
initial values of I1 and I2 are zeros. I need to find the value of I1 and I2 at corresponding time = 1, 2, 3 .... 10 secs and then draw the plot till 100 secs.
Can somebody help me in finding the solution to this question. or maybe if someone can guide me if this can be done in MATLAB and how....I will be really greatful thanks a lot
  #2
Old 10-18-2005, 08:19 PM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
Were you provided component values for R1, R2, C, and L as part of the problem?
hgmjr
__________________
"No human being should be allowed to have this much fun."
hgmjr
May we never lose compassion for those who need our help and encouragement.
  #3
Old 10-18-2005, 08:45 PM
Default
yes, R1= 100, R2 = 50, C = 0.001, and L = 2
Quote:
hgmjr
  #4
Old 10-21-2005, 05:48 PM
hgmjr's Avatar
Super Moderator
Default
Hi Friendforall123,
After thinking about the best way to analyze your circuit I believe the easiest way to get to the answers you seek is by using vector analysis.
There is a very good Vector Analysis Tutorial located on this website. I recommend that you take a look at the material and then take a shot at applying it to your circuit.
One of the first things you will need to do is determine the capacitive reactance and the inductive reactance in your circuit. HINT: You can find the value of ω from the expression for the source voltage.
Next, You will need to find the total impedance of your circuit.
For example, I performed the analysis and for the current (I2) flowing just in the branch containing the series combination of R2 and L and came up with the following value.
I2 = 0.1347/-45.00 amps (polar notation) (Updated my figures)
or in complex number notation
I2 = 0.0952 - j0.0952
-------------------------- Edited on 10/24/05 --------------
The value of I2 given above is true for all values of E = 20*sin(15t) in which t = (2*pi*n)/15 where n is a member of the set of positive integers greater than or equal to 2.
Once you have found both I1 and I2 you will be able to write the expression that will allow you to calculate the value of each at the time points you mentioned in your posting. Also with the same expressions you can put them into an EXCEL spreadsheet and plot the values all the way out to 100 seconds.
If you will post your answers, I will compare them to mine.
Good Luck,
hgmjr
__________________
hgmjr
Tags
Related Site Pages
Section Title
Worksheet Calculus for electric circuits
Worksheet Phasor mathematics
Worksheet Time constant calculations
Textbook Calculating power factor : Power Factor
Textbook Resonant filters : Filters
Textbook Resonance in series-parallel circuits : Resonance
Textbook Simple series resonance : Resonance
Textbook Simple parallel (tank circuit) resonance : Resonance
Textbook AC inductor circuits : Reactance And Impedance -- Inductive
Textbook Circuit components : Using The spice Circuit Simulation Program
Similar Threads
Thread Thread Starter Forum Replies Last Post
741 Op Amp Transistor Circuit Trouble kim89 Homework Help 4 09-18-2013 08:49 PM
Generator Pre-Lube/Post-Lube Circuit (NOT FOR A VEHICLE!!!) rtbcoop The Projects Forum 1 04-02-2013 10:20 PM
2 stage switch design using mono-stable multivibrator circuit. HELP! mattaus The Projects Forum 1 03-23-2013 03:41 AM
help me design an audio based camera controller circuit mehmehmeh The Projects Forum 8 03-21-2011 06:19 PM
555 timer circuit for servos MoC General Electronics Chat 4 03-18-2010 12:33 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
