All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #41
Old 12-18-2008, 06:55 PM
slisgrinder slisgrinder is offline
Junior Member
Default
yup that looks great. now onto the driver circuit...since i already ordered the mosfets (IRF540), what is a driver circuit anyway...
since the arduino supplies 5V at 40mA max to the gate, do i really need a driver circuit?
  #42
Old 12-18-2008, 07:16 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
IRF540 MOSFETs are standard N-channel MOSFETs. They will not work properly unless Vgs reaches 10v. This is why I specified logic level MOSFETs.
Now, IRL530's, IRL640's are also logic-level MOSFETs. Notice the "L" instead of the "F". That one letter makes a big difference.
Ordering the wrong MOSFETs will cause the circuit to be unnecessarily complicated.
Why don't you order some IRL530 or IRL540 MOSFETs from Digikey? They will ship them quickly, and this will keep your project much more simple.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #43
Old 12-18-2008, 07:22 PM
Junior Member
Default
what about an irl510?
  #44
Old 12-18-2008, 07:27 PM
SgtWookie's Avatar
Expert Member
Default
That might work, but it has a much higher Rds(on) than the 530's and 540's. This means more power loss in the MOSFET, which means greater power dissipation. If you want the MOSFETs to run cool (which you do!) then use MOSFETs with a low Rds(on).
The IRLZ24 and IRLZ34 are less expensive than the IRL530/IRL540. But for some unknown reason, you seem to like to choose other parts than what are recommended.
__________________
General info:
  #45
Old 12-18-2008, 07:36 PM
Junior Member
Default
well, the irf540 are on their way...i guess i will have to use those...the supplier (lee electronics, the closest to where i live (calgary)) only has irl510 but not in stock so i guess i will have to use a driver circuit and stick with the irf540...
  #46
Old 12-18-2008, 07:42 PM
Junior Member
Default
so what is a driver circuit anyway...
  #47
Old 12-18-2008, 07:47 PM
SgtWookie's Avatar
Expert Member
Default
A driver circuit translates the 0v-5v output of your Arduino uC to the 0v-10v required by the MOSFET gate.
__________________
General info:
  #48
Old 12-18-2008, 07:52 PM
Junior Member
Default
how do you accomplish this? by having a transistor, and since this is a pwm signal, a transistor wouldnt work so...what am i suppose to do...i thought the gate-source voltage was +-20V?
  #49
Old 12-18-2008, 08:09 PM
SgtWookie's Avatar
Expert Member
Default
See the attached schematic.
V1 is just a signal generator, but it represents the 0v-5v output of your Arduino uC.
The rest is to handle the charging/discharging of the MOSFET's gate.
The 1N4148 really should be a 1N4150. A 1N4148 won't handle enough current.
R5 represents the load.
__________________
General info:
  #50
Old 12-18-2008, 09:02 PM
Junior Member
Default
so this schematic you just made it for the irf540? wow, thats cool...
Tags
Related Site Pages
Section Title
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Voltage controlled PWM for LEDs garch The Projects Forum 12 12-02-2009 06:52 AM
Charlieplexing RGB LEDs? johan General Electronics Chat 13 10-30-2008 05:48 PM
Desktop Computer controlled car rakan Embedded Systems and Microcontrollers 5 11-02-2007 11:00 PM
Driving Common-Cathode RGB LEDS in PWM mcanever The Projects Forum 8 04-12-2007 01:18 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
