So there was a question on my final I just took that had a bunch of parts to it. I could do all but the last part. Here is basically what the question said without giving actual numbers:
You have a system described by the following state space:
dx(t)/dt = Ax(t)+Br(t)
y(t) = Cx(t) + Dr(t)
If it helps at all, D was equal to 0. The rest were given in my problem of course, but they are not relevant to answering my question.
It then asks the following question (and I'll highlight the last one, the one I didn't know how to do)
a) Is the system BIBO stable?
b) Is the system completely observable?
c) Is the system completely controllable?
d)
based on part c above: i) If the system is NOT CC, what needs to be done to matrices B and/or C to make it so
ii) If the system IS CC, what gain values for the K = [k1 k2] using the control law r(t) = K * x(t) would yield a double eigenvalue of -2?
Now, I know what eigenvalues are, and I know how to do everything up to that point, and I would have known how to do part i) if the system was NOT CC, but it was. So what in the world does it mean to say that these gain values would "yield" a double eigenvalue of -2?
In this case, just so you're made aware, the transfer function I solved for was not a matrix, it was something like
\(H(s) = \frac{20}{(s-1)(s+4)}\)
So basically, while on one hand I'm saying I don't know how to do the problem, my bigger question is what does the question mean? If I knew abstractly what it meant, I could have easily come up with an equation and solved for k1 and k2.
Thanks guys,
-blazed
d)
Thanks guys,
-blazed
