hello everyone, before i ask my question i just wanted to say wonderful site!!
I'm making my car have a push to start ignition system, i have attached a quick draw that i have made
the way it works is like this:
you get in the car, flip a bulgin spst switch (in the picture i don't have a relay there, im probably gonna add one)
then you have to swipe a rfid fob, when you do that the rfid board will trigger a relay that will trigger 3 other relays for 15 seconds.
those 3 other relays trigger the starter wire accy wire and the ignition wire, from the car.
with the accy and ignition wires getting 12v the car is almost on
there is a momentary push button switch (Honda s2000 starter button) that must be pressed for a sec or two to get the engine running.
here is the deal, the rfid kit has a jumper to keep the relay on for 5 or 15 seconds, that means i have only 15 seconds to start the car and when i do start it, this means it will keep the car on for only 15 sec because it will close the relay after that, shutting down the car.
my question is what can i use to help me out, i want to use the rfid to trigger some sort of IC i guess, and then the IC will keep the relays on, so i guess an IC that can have a momentary button turn the relays on and keep them on....
the rfid board as 4 empty pins marked 5v gnd tx rx, im guessing that's the ttl serial for programing, maybe i can program the relay to stay on all the time instead of 5 or 15 seconds, just a thought though
thank you for your help
cheers
seesoe
cheers
seesoe
