Static electricity sensor experiment
jut
Joined Aug 25, 2007
224
http://www.allaboutcircuits.com/vol_6/chpt_5/9.html
I'm having trouble with this experiment-- can't get the LED to turn on/off as experiment describes.
First off, I've tried two different N-channel JFET and get the same results: NTE312 and MPF102 (radioshack).
I understand that if you reverse bias the gate, by touching one hand on the 100K resistor and the other on the (-) side of battery, it should pinch off the N channel and no current should flow, turning the LED off.
However, here's what I noticed:
1. With the 100k resistor floating, the LED is randomly on or off. Draws about 8 mA.
2. When I touch the floating resistor with just one hand the LED dims. Draws about 2 mA. Maybe my body has a (-) charge?
3. When I touch the resistor with one hand and touch the (+) supply with the other the LED brightens with a current of 12 mA. This was expected.
4. When I touch the resistor with one hand and touch the (-) supply with the other the LED brightens with a current of 7 mA. Not expected. I would have thought the LED would turn off. But the current did decrease.
5. Connecting the resistor directly to the (-) supply brightens the LED with a current of 9 mA! Not expected!
Any suggestions??
Wendy
Joined Mar 24, 2008
23,797
Interesting experiment. Never done it though.
You might try to make an insulated plate to increase the surface area. Just a thought.
davebee
Joined Oct 22, 2008
540
This is like Bill Beaty's detector circuit. He has a few troubleshooting suggestions on his web page you could try.
http://amasci.com/emotor/chargdet.html
How are you measuring the current? With an ammeter in the circuit? If so, where is it? I'm wondering could it be adding a voltage drop that's messing with the FET bias?
jut
Joined Aug 25, 2007
224
I'm using a fluke 179 DMM as an ammeter connected between the + side of the battery and the + side of the LED. I get the same results without measuring current.
hobbyist
Joined Aug 10, 2008
892
Hi
I know what you mean, I was experimenting with jfets one time and was getting weird results too, but I think I put a resistor from ground to the source of the fet, and then applied a more neg. potential to the gate and got better results.
mik3
Joined Feb 4, 2008
4,843
To pinch-off (turn off) a JFET you need to apply a negative voltage (less than zero) to its gate with respect to its source. By touching the gate and the negative side of the battery the voltage between the gate and the source is zero (almost but very close) thus the JFET conducts its maximum current.
mik3
Joined Feb 4, 2008
4,843
If you connect its source to the led side and its drain to ground it will work as the experiment describes.
