Power amplifier help
kahafeez
Joined Dec 2, 2008
150
Hi people, i need to make a power amplifier for the following application. plz suggest me a simple as possible power amplifier which works in the audio range that is from 20Hz to 20KHz bcz my application works on 40KHz and 50KHz. i just need this plz help. thanks. and with the least components plz. the power amplifier i need should have a gain of 30dB.... and also tell me that how should i calculate the power of my FSK signal as shown in the attached image http://i452.photobucket.com/albums/qq242/kahafeez/myrequirement.jpg
kahafeez
Joined Dec 2, 2008
150
thanks dude, i dont really want 80Watts.....
i found this IC called LM386 which gives 1Watt. and LM380 which gives 2.5W. thanks
bertus
Joined Apr 5, 2008
22,938
I think the LM380 and LM 386 do not reach such high frequencies.
The LM12 reaches 100 khz.
Greetings,
Bertus
Audioguru
Joined Dec 20, 2007
11,248
The circuit drives an antenna. It must be an extremely long antenna for such a low frequency.
The LM386 little power amp has a response that is -3dB at 300kHz when its gain is 20 (26dB).
