All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-24-2008, 04:58 AM
Meloncoly Meloncoly is offline
Default Designing a 3-8 decoder with multiple 2-4 decoders
The problem asks me to make a 3-8 decoder (no enable input required), with inputs x,y,z and 8 active high outputs labelled 0-7. The only building block I can use is a 2-4 decoder with active high enable.
I didn't listen much in class, regrettably so I don't know much of the terms nor how I'm really supposed to approach this, so please help me along the way.
Right now I have two 2-4 decoders, one representing 0-3, and another representing 4-7. Input x is connected to both the decoder's active high enable. Input Y and input Z are connected in the regular inputs of the respecting decoders.
I think this is correct, but what am I missing. I was thinking, that if I didn't place a inverter before the enable on the top or bottom decoder, then the decoders won't be labelled 0-7 but rather two seperate entities. Am I correct in thinking that? Or is there a way where I can "assign" one decoder to be 0-3 without the use of an inverter?
Also, how is active high and active low represented. If a bubble is on the enable of the decoder, does that mean active high or active low? How about when the bubble is on the output of the decoder? Is that representing active high or active low?
Thank you for the assistance.
  #2
Old 11-24-2008, 12:34 PM
beenthere's Avatar
beenthere beenthere is offline
Default
Our chapter on logic will answer you question on the bubbles - http://www.allaboutcircuits.com/vol_4/chpt_3/1.html.
__________________
First comes the hardware, then the software.
  #3
Old 11-11-2010, 02:06 AM
johncurran94 johncurran94 is offline
Default
Quote:
Originally Posted by Meloncoly View Post
If you checkout sn74138 and a and sn74139 and compare the circuits and the truth table it will give you some help
  #4
Old 11-11-2010, 02:15 AM
shteii01 shteii01 is offline
Default
Scroll down to Demultiplexers section, it shows the 3 to 8 using two 2 to 4: http://www.doc.ic.ac.uk/%7Edfg/hardw...eLecture12.doc
  #5
Old 11-11-2010, 03:09 AM
retched's Avatar
retched retched is offline
Default
?? 2 of the same exact threads, with different ops???
Must be close to final exam time.
@shteii01 That is a very informative and easy to grasp lesson. Good find.
__________________
-rm-
  #6
Old 11-11-2010, 04:18 AM
Default
Thank you.
Tags
Related Site Pages
Section Title
Worksheet Sum-of-Products and Product-of-Sums expressions
Worksheet Flip-flop circuits
Worksheet Latch circuits
Worksheet Multiplexers and demultiplexers
Worksheet Encoders and decoders
Worksheet Simultaneous equations for circuit analysis
Worksheet Series and parallel AC circuits
Textbook Parallel-in, parallel-out, universal shift register : Shift Registers
Textbook Asynchronous counters : Sequential Circuits Counters
Textbook Digital signals and gates : Logic Gates
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help, designing a keypad matrix decoder fyanardi Homework Help 3 06-08-2009 04:22 AM
Multiple Load Switching Using Momentary NO Switches spstnwor The Projects Forum 6 04-28-2008 10:39 PM
Build an 8x1 MUX / Build a 3x8 Decoder Joppalowe Homework Help 2 02-25-2008 03:04 PM
decoder and register in Verilog notwist Programmer's Corner 1 11-22-2007 04:44 PM
Urgent help required in Designing a Decoder. m_roy Homework Help 2 11-01-2006 01:03 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
