How can i make my own solid state voltage regulator using transistor, capacitor, diod, resistor and any electrical things needed for the voltage regulator?
The input rages from 8V-11V and the output is a constant 6V?
I also need to built my own over voltage relay protection where the input will cut-off if over 12V is supplied?
Input 8V - 11V --- Output 6V+Over voltage relay protection?
Please list down the things needed and the circuit drawing?
I need to submit this project before 25th Nov?
