*SG3525: Pin Connections
JUAN DELA CRUZ
Joined May 27, 2008
121
Hi guys.. I've a trouble using SG3525 PWM controller IC..
Here are my questions..
1. What is the formula needed to calculate the Osc. frequency (not shown in the datasheet attached) ?
2. The frequency of the OUTPUT A (pin 11) & OUTPUT B (pin 11) is ½ the OSC. Output (pin 4) frequency ?
3. How can shutdown the SG3525? ...by holding SHUTDOWN (pin 10) "high" ?
Thank you
JUAN DELA CRUZ
Joined May 27, 2008
121
Thank you ^_^
jpanhalt
Joined Jan 18, 2008
11,087
The datasheets do not show a simple formula to use. You have to go to Figures 1 and 2 from which oscillator timing for various resistances and capacitors can be determined graphically.
Pin 10 is shutdown; alternatives are described on page 2.
The datasheets for the Linear equivalent are the same.
John
JUAN DELA CRUZ
Joined May 27, 2008
121
John
Thank you sir for th info... ^_^
One more thing Sir ....is the output frequency of pin 11 (OUTPUT A) & pin 14 (OUTPUT B) is ½ the OSC. OUTPUT (pin 4) ? Thank you
bertus
Joined Apr 5, 2008
22,277
The flip-flop will divide the clock frequency by 2.
The latch will deliver the pulse width.
Greetings,
Bertus
Wendy
Joined Mar 24, 2008
23,421
I don't have much to add (I was asked offline) but page 4 on your pdf file was interesting, looks like a practicle guide to use. Interesting chippie though, I could see trying to use it myself.
JUAN DELA CRUZ
Joined May 27, 2008
121
Greetings,
Bertus
Thank you for both of you.. ^_^
How about the exact/ right formula in calculating the output frequency ?
...I need a 50HZ/ 60Hz output ƒ
bertus
Joined Apr 5, 2008
22,277
In the datasheet the shutdown is done by connecting the shutdown-pin to Vref using a 2K resistor.
An other possibility is holding the softstart pin low via a 5 K resistor.
Greetings,
Bertus
JUAN DELA CRUZ
Joined May 27, 2008
121
Greetings,
Bertus
Thank you sir.. ^_^
1. How can I do that "automatically".. I mean to SHUTDOWN the SG3525 at a voltage for about approx. 11.8V ? Do I need an op-amp voltage comparator to detect the battery voltage (Sg3525 supply) variation from 13.8V to 11.8V ?
2. How about the exact/ right formula in calculating the output frequency ?
...I need a 50HZ/ 60Hz output ƒ @ OUTPUT A & B (pins 11/14)
..and a 100Hz / 120Hz @ OSC. Output (pin 4)
Wendy
Joined Mar 24, 2008
23,421
The problem is there are no formula's. I don't know if this means it isn't predictable enough, or if it was just too complex to list. If the freq is X2 whatever you actually need then you'll probably need to figure out a charge time and discharge time from Figure 1 and Figure 2 that will give you the freq you need. In other words, use the charts to calculate values, and it won't be a symetrical square wave.
You'll probably have to breadboard one to pin the values down for real, and even then use variable parts (such as variable resistors).
The shutdown as I interpret it assumes a ground, a high voltage level shuts it down. I'm not sure of it though.
JUAN DELA CRUZ
Joined May 27, 2008
121
How can I calculate the values of RT & CT needed to have a 100Hz/ 120Hz output from the Pin 4 (Osc. output) using these charts.
I need some assistance here 'coz I'm an undergraduate... didn't know the relation between the charge/ discharge time to the output frequency ^_^
Thank you
Wendy
Joined Mar 24, 2008
23,421
My best guess (and it is a guess) is to break it down. The charge time plus the discharge time should equal the period.
If you want 100Hz the period is 10ms, 10000 μs. Figure 1 shows using a .1μF cap this should be around 150KΩ to 180Ω. The discharge is going to be small no matter what, so go for 470Ω for 180μs.
10000μs + 180μs = 10180μs, which should work out to 98Hz.
Again, this is a guess. Never used the chippie.
JUAN DELA CRUZ
Joined May 27, 2008
121
Thank you Mr. Bill ^_^
Hmmmm... I'm quite confuse. How about for 120Hz Osc. output?
bertus
Joined Apr 5, 2008
22,277
The cycletime = 1 / frequency.
For 120 Hz => 1/120 = 8.333 mSec = 8333 μSec.
So look in your graphics for the resistor value with a capacitor of 0.1 μF.
Greetings,
Bertus
JUAN DELA CRUZ
Joined May 27, 2008
121
I've noticed that the discharge time is affected by RD (DISCHARGE resistor) shown in the second chart. That is, I think should be connected to CT & DISCHARGE pins. So, the discharge time and the charge time is independent to each other. That is, the charge time is controlled by RT & CT... and th DISCHARGE time is dependent to the value of RD (Discharge resistor) and CT. What do you think ?
bertus
Joined Apr 5, 2008
22,277
I think you should add the charge- and discharge- time to calculate the cycletime.
I think it is a sawtooth generator with seperate charge and discharge resistors.
Greetings,
Bertus
JUAN DELA CRUZ
Joined May 27, 2008
121
I think the formula in calculating the Osc. output ƒ is 1.44 / RT (in ohm) x CT (in Farad)...
So, for OUTPUT A & B ƒ = 0.7 / RT x CT
I based it in a given tested oscillator output frequency in the SG3525A datasheet. Here is the portion of the SG3525A datasheet.
JUAN DELA CRUZ
Joined May 27, 2008
121
So, I think using this formula..
ƒ = 1.44 / RTxCT
RT = 120kΩ, & CT = 0.1µF ..for 120Hz Oscillator output frequency
RD (discharge resistor) must have a low resistance for faster discharge..
I chose 100Ω (for approx. 25µS discharge time) using the same value of CT (0.1µF)
What do you think sir?
bertus
Joined Apr 5, 2008
22,277
I think your calculations are correct.
Keep in mind that a capacitor can have a tolerance up to 20 %.
The resistor also takes part in the tolerance question, depending on the type you use.
Greetings,
Bertus
SgtWookie
Joined Jul 17, 2007
22,230
I think that you can attempt to derive a formula all that you wish, but at best "your mileage will vary".
I looked at a datasheet I downloaded from ST Microelectronics. It doesn't have a formula either; two separate charts for charge and discharge times.
The recommended oscillator frequency range is from 100Hz to 400kHz. You are attempting to operate this IC at the extreme lower end of the recommended range.
I suspect that the charge/discharge response curves will tend to vary significantly over temperature when you're running the IC at nearly minimum or nearly maximum frequencies. You will have to verify operation by testing.
It wasn't designed to be a precision oscillator; merely oscillate in a ballpark range.
It sounds to me like you're trying to build a UPS or inverter. That isn't what the IC was designed for. It was designed for use as a building block in a DC-DC switching power supply.
