All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-20-2008, 08:28 AM
sgraeber sgraeber is offline
Question Skin-Temperature-Sensor: sensor-type & circuit design?
Hello everybody,
I am quite new in all this electronics and circuits stuff, but I have to deal with it somehow, as I need some basics for a studies related project. Unfortunately I do not have a clue, so hopefully I can bother you with some of my questions ...
My current task is to find a circuit design for measuring skin temperature. I already developed some ideas on that, but I am not sure, if I am doing right.
So this is, what I want to achieve:
What temp range?
"normal" skin-temperature is 32/33C; Temperature Range in certain conditions can be between 31C and 37C
So range 31C - 37C is required.
Accuracy?
Different medical devices use different values here. I think for me 0.1C is ok.
Response time?
Seconds should be ok.
Distance?
direct skin contact - some mms
Output?
analog
Other requirements?
- Sensor should be as small as possible (plan is to built the sensor into a mobile phone)
- Sensor should work with +5V
Do you recommend any sensor-device for this application? I thought about the LM35 (http://www.national.com/mpf/LM/LM35.html). Is this a good choice? Or can you recommend anything better, smaller, ...?
Further, I have this circuit diagram - which I am not sure is a good one (see attached file skintemperature.jpg) Would be happy for any help with this circuit diagram (as I do not know, if this could work for me): does this circuit diagram make any sense for what I want to achieve?
Sorry, this sounds like a stupid question, but this is the first time that I try to design such stuff ...
Thank you very very much for all of your efforts in advance.
Hope to get some answers here, that might help me.
  #2
Old 10-20-2008, 08:52 AM
tmd_63 tmd_63 is offline
Junior Member
Default
The LM35CAZ is a very good device with a nice 10mV/degC output. Your requirement should give an output range of 310mV to 370mV.
If you use a stable 10x amplifier then you will get 3.1 to 3.7V without too much noise. Although, if you are inputting to an ADC, you could keep the component count down by a direct feed to the ADC.
  #3
Old 10-20-2008, 09:05 AM
Default
Thank you very much for your fast reply and your recommendation to go with the LM35CAZ. Good to hear, that my initial choice of the LM35 is not too bad.
Can you recommend any sable 10x amplifier?
Sorry, but I did not understand much about the ADC-part. I planned to connect the sensor to an ARDUINO-board, which than would do the analog-digital conversion. Or am I wrong?
Thank you again for all your time and efforts!
  #4
Old 10-20-2008, 09:08 AM
Default
Oh. I just forgot. Would this work with the circuit diagram that I posted earlier? Sorry, to ask, but this is the first time a do such a circuit design.
  #5
Old 10-20-2008, 12:04 PM
beenthere's Avatar
beenthere beenthere is offline
Default
Your op amp has a gain of 5 as drawn. Reduce the 500K to 100K, and the 100K to 10K and you have g gain of 10. You could go as low as 20K and 2K.
__________________
First comes the hardware, then the software.
  #6
Old 10-20-2008, 12:30 PM
scubasteve_911 scubasteve_911 is offline
Default
I would also investigate thermopile sensors, they're faster because of zero-thermal mass and can be accurate. It is also easy to seal them, so that you can actually integrate it into a cellphone.
MLX90247-ESF-DSA Is available from digikey.
http://www.melexis.com/prodfiles/000...090247P006.pdf
Steve
  #7
Old 10-21-2008, 09:38 AM
Default
Thank you very much for the idea with the IR sensors. Actually they seem to fit my needs even better than the LM35, as the LM35 has "only" a 0.25C accuracy.
Unfortunately I do not understand much about the IR-sensor you suggested. Any ideas how to measure absolute temperature?
Maybe you can help me out with some schematics?
I really appreciate all your help on my (long) way in understanding electronics
Thanks!
  #8
Old 10-21-2008, 01:54 PM
beenthere's Avatar
Default
The voltage out of the thermopile is relative to the difference between that of the thermopile itself and the isolated wafer. The buried thermistor has to be read to know the thermopile temp before the incident temperature difference can be converted to an absolute temperature.
The thermistor is non-linear in its response, so compensating to produce an absolutely correct result is challenging with analog circuitry. Reading both with a microprocessor and doing the calculations is pretty simple. Notice that the Metaxis suport chip needs a serial clock to read out its values, so it is also predicated on some microcontroller.
The ARDUINO should be able to handle the thermopile, assuming the A to D converter has enough resolution.
__________________
  #9
Old 10-22-2008, 08:01 PM
Default
No problem,
I would use their interface IC with the sensor, then read it into your ADC as beenthere suggests. You would apply the equation given in the datasheet to find the temperature.
I don't really know what kind of precision you can get with this sensor. The LM35's +/-0.25C is actually pretty good! You would be hard pressed to get better than this with the thermopile. The advantages, as I mentioned, is that you can creatively seal this into a cell-phone through an IR window. Also, with less thermal mass, you can measure faster. Also, it is less prone to 'parasitic' heat, or heat that you do not want to measure, since it is directional.
Steve
  #10
Old 08-30-2009, 07:47 PM
DoctorLes DoctorLes is offline
Default Re: MLX 90313 external circuitry?
I've found this thread to be helpful for my own project involving a thermopile and my Arduino. However, after looking at the PDF for the thermopile support chip you described, it makes incomplete reference to external components and circuitry. Without understanding this part, I'm back to an impasse.
The PDF does show a simple Op Amp circuit, using Melexis' AD8628, which is similar to the one I use but omits the temperature compensation circuit, it seems. It labels "Vref" for setting an offset voltage of some sort, but does not give enough detail for this either.
Right now, I've got a seemingly working circuit using an op amp, increasing the tiny voltage output of my thermopile, and fed into one of my arduino's ADC ports.
I've found and adapted an Arduino sketch that sends the data to the serial port; my monitor shows rapidly scrolling C and F readings.
My eventual challenge is to find a Processing sketch that will convert this data to a dynamic bar, or some other graph type. I've spent a lot of time researching that part already but have not found one suitable for adaptation to my project.
Thanks,
Tags
Related Site Pages
Section Title
Worksheet Encoders and decoders
Textbook Practical considerations of ADC circuits : Digital-analog Conversion
Textbook Thermocouples : Electrical Instrumentation Signals
Similar Threads
Thread Thread Starter Forum Replies Last Post
Circuit Design Problem: current drive voice coil for shaker table tiantiandog Homework Help 3 01-10-2010 11:46 PM
Circuit Design Help - Timer for Automotive J.Green The Projects Forum 1 07-16-2008 06:00 AM
How to design an egg timer circuit? JLam Homework Help 2 03-21-2008 04:36 PM
RF Circuit Design hectic-j Radio and Communications 4 04-21-2007 05:50 PM
Electronic Circuit Design Help Needed. R.Stephen The Projects Forum 4 12-05-2006 08:01 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
