All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-16-2008, 07:10 PM
Stearman Stearman is offline
Default 12 volt relays
I would like to energize a relay to close the contacts for a one shot pulse, and when I de-energize the relay have it close the contacts for another one shot pulse. The pulse could be a few milliseconds.
Is there such a relay? If so, what do I call it?
  #2
Old 10-16-2008, 08:27 PM
KMoffett KMoffett is offline
Default
This works. The pulse width depends on the value of the capacitor, and the resistance and inductance of the relay coil. I don't think you will get pulse widths of "a few milliseconds", since relay switching times are usually 100 mSec or longer.
Ken
  #3
Old 10-16-2008, 09:20 PM
Bernard's Avatar
Bernard Bernard is offline
Default pulse-pulse
I have seen some high speed relays, but none as you describe. What is the nature of your pulse ? My take is: use two diffrentators [.1μF & diode,k to c], NO & NC relay contacts to free end of caps. Connect outputs to a diode OR gate [k's tied together and connected to 10kΩ]. To discharge caps connect 1kΩ from NO & NC to ground. With a voltage applied relay armature [ or switch ] energising relay, one pulse will appear at 10kΩ, when relay opens another pulse will appear. It's a start, sometheng to throw rocks at.
  #4
Old 10-16-2008, 11:26 PM
mik3's Avatar
mik3 mik3 is offline
Default
If you want fast pulses then use solid state relays. They are noiseless (acoustically), lot faster than ordinary ones and do not produce arcing (between contacts on ordinary relays).
  #5
Old 10-16-2008, 11:32 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Mechanical relays and switches have "contact bounce" whether they're closing or opening. This can take quite a while to settle out - perhaps several hundred mS. Not sure what you're trying to do, but if you need clean on/off pulses, then you need to go for a semiconductor solution.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #6
Old 10-17-2008, 05:51 PM
I may have misled you with the "few millisecond" close time. The close pulse time is not critical.
I'm switching an intercom on and off in an old bi-plane. The way the radio intercom works is that when you momentarily ground the intercom input it switches the intercom on. You then have to ground it again to switch it off.
I would like to have the intercom on as long as I hold a spring loaded toggle switch on in the cockpit.
I want to switch a relay to ground the intercom input with a pulse when I engaged the toggle switch and ground the input again with a pulse when I release the toggle switch.
Thanks for all the inputs. I really appreciate them................
  #7
Old 10-18-2008, 12:32 AM
SgtWookie's Avatar
Expert Member
Default
I should've guessed via your login name
So, is your Stearman certified for type, or experimental?
If it's certified for type, you should not make any changes from the original aircraft specifications.
If you're experimental - well, there is some more leeway. However, this mod is certainly not something you would want to do to get your aircraft out of certification for type.
Stearmans are wonderful aircraft. I am truly envious that you have one that's flyable. If there were some way I could afford one, I'd have one and be performing barrel-rolls, loops and Immelmans across the skies of Orlando.
Basically, changing anything in your aircraft risks having it undergo a re-certification as an experimental aircraft. If you are currently certified in-type, you do not want to have this happen.
Along with this, your joystick comm switch is likely SPST, which means that it will be extremely difficult to "de-bounce". I can only suggest to you in the most respectful way that you do NOT want that kind of distraction while you are aloft. If you should happen to get a "contact bounce", your comm may toggle quickly from on to off - and then while you're still holding the switch down, your comm is off. When you release the switch, then your comm is toggled on, and you'll be confused; how do I get back to my radio? If you get too involved in this, things could get bad quickly.
If something happens on a flight, pilots are all too prone to forget that their primary function is to "fly the aircraft".
I know that you want this modification - but from many years experience and with a great admiration and respect, I recommend against it.
Odds are too great that problems will develop, and the curious pilot will wind up trying to troubleshoot in flight - forgetting that their primary duty is to fly the aircraft.
Enjoy the aircraft for what it is; along with it's quirks. The closer you can get it to original specifications, the better.
Yeah, it's old. But it's wonderful. Please preserve it for the next generation.
Not many Stearmans around anymore.
__________________
General info:
  #8
Old 10-18-2008, 01:09 PM
raybo raybo is offline
Junior Member
Default
you are describing an oscdillator. you can try using a cap to do that and a relay. sometimes it is called a buzzer.
  #9
Old 10-18-2008, 04:47 PM
Default
Quote:
What?
Ken
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Design Project: Event counter
Worksheet Flip-flop circuits
Worksheet Electromechanical relay logic
Worksheet Switches
Textbook Monostable multivibrators : Multivibrators
Textbook NAND gate S-R flip-flop : Digital Integrated Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Making 12 Volt System out of 6 Volt Batteries Faffy General Electronics Chat 16 04-27-2008 01:54 AM
6 Volt Positive DC conversion to 12 Volt Negative Gary Sandberg General Electronics Chat 7 02-11-2008 02:20 AM
Needing a series-parallel combination resistor circuit calculator jasonbengiat The Projects Forum 1 03-13-2007 08:47 PM
Digital volt and Amp gauges Edison General Electronics Chat 7 06-12-2005 05:52 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
