All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-28-2008, 07:34 PM
Greg23 Greg23 is offline
Default DC 12 volt 100 amp power supply
I'd like to find schematics to build a variable power supply.
I'm starting with a 120v 10 amp AC outlet.
I'd like to build a constant 12vdc with a variable knob
for 1A to 100A. I don't know if this possible but maybe
someone out there can help or steer me in the right direction....
  #2
Old 09-28-2008, 08:58 PM
scubasteve_911 scubasteve_911 is offline
Default
You cannot have a constant voltage and specify a current at the same time. You must mean that you want an adjustable over-current protection knob.
The schematic really isn't the difficult part of the project, it will be the implementation. Finding a 1.2KW transformer for this is going to be difficult. You are going to need some extremely beefy rectifiers and a lot of bulk capacitance.
Do you really need 100A? That is a massive amount of current, you are going to need some very thick lines for that!
Steve
  #3
Old 09-28-2008, 09:54 PM
Default
Thanks for your reply Steve,
Your answer proves my obvious ignorance here.
I don't know a whole lot about electronics.
Are you saying that amp & volts will increase and
decrease in proportional measures regardless of circuitry ?
I don't necessarily need 100 amps but I'd like to be able
to adjust from 0-12 volts and 0-75 amps or so.
It looks like a large transformer will be a part of this ?
Would it be easier for an novice like myself to purchase
something already built ?
  #4
Old 09-28-2008, 10:13 PM
cumesoftware's Avatar
cumesoftware cumesoftware is offline
Default
Quote:
I concur with scubasteve, but you will need a 2.16KW transformer (multiply 1.2KW by 1.8), fact that only worsens the problem.
__________________
I love the smell of toasted transistors in the morning.
  #5
Old 09-28-2008, 10:15 PM
Default
No problem Greg,
I was saying that you cannot control both current and voltage at the same time.
A voltage supply will give a constant voltage, despite load changes. The current varies to the load to keep the necessary voltage across it.
A current supply will do the opposite. It wants to maintain a constant current to the load, so it will vary its voltage to try to make it happen.
From these explanations, you know that to have both is impossible.
If you need an adjustable regulator, that might be a challenge. I do not know of any commercially available IC that will perform this task, they are usually limited to about 5-10A. You would need to design something along the lines of the following link, except your reference voltage will be adjustable.
http://tangentsoft.net/elec/opamp-linreg.html
The 0-75A must be a current-limit / shutoff input. So, if you sense more than x amount of amperes, then you can disable the output of the supply. It is also possible to switch between a voltage-source and a current-source, but this is more complicated.
If you are a beginner in electronics, I don't think it is feasible to build something of this magnitude. If you are the dedicated and have lots of time to spare to learn, build, and potentially have to repeat the design process, then perhaps you should attempt this.
I have a lot of design work to do on my own, so I cannot be specific with my answers.
Goodluck!,
Steve
  #6
Old 09-28-2008, 10:18 PM
Default
cumesoftware is right about the 1.8 multiplier, I guess I have been working with switching regulators too long, where I am thinking that I can approximate 100% efficient calculations :P
Linear regulators are notoriously inefficient.
Steve
  #7
Old 09-28-2008, 10:35 PM
Smile
Thank You Steve!
Your input has helped alot.
Thanks for taking the time to reply.
Greg
  #8
Old 09-28-2008, 11:47 PM
Default
You're very welcome, sorry if I discouraged you. If you attempt making this, please keep us updated and feel free to ask for guidance.
Steve
  #9
Old 09-28-2008, 11:55 PM
beenthere's Avatar
beenthere beenthere is offline
Default
Lambda used to make supplies that would put out voltages and currents like that. They weighed at around 60 pounds. They used a preregulator section with an SCR full wave regulator so the filtered voltage was about 2 volts above the desired output. That way, the pass transistors could run in saturation and minimize ohmic losses. I would hate to try to duplicate all that ironmongery.
__________________
First comes the hardware, then the software.
  #10
Old 09-29-2008, 08:52 AM
studiot's Avatar
studiot studiot is offline
E-book Developer
Default
100Amps (or so).
Well, to put this into perspective, houses in the UK normally have a 100 amp main fuse.
At 12 volts you can get 100+ amps from automotive cold start machines, although not for sustained periods.
You can also achieve this level of current from welding trnasformers.
Do you have you basic supply sorted?
I suggest you do this before worrying about control options.
It is also pertinent to enquire what you are going to do with this supply?
If you have split loads you may find it adequate to run with several smaller 12 volt supplies fed from a common source.
This would also be more reliable and reduce wiring needs.
Tags
Related Site Pages
Section Title
Worksheet Power conversion circuits
Worksheet Regulated power sources
Worksheet Th'evenin's, Norton's, and Maximum Power Transfer theorems
Worksheet Performance-based assessments for DC circuit competencies
Textbook Voltage regulation : Transformers
Worksheet Performance-based assessments for basic electricity competencies
Textbook Active-mode operation : Junction Field-effect Transistors
Textbook Current mirrors : Bipolar Junction Transistors
Textbook Active mode operation : Bipolar Junction Transistors
Textbook Zener diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
What causes a computer power supply to fail? Mark44 Computing and Networks 22 08-09-2010 02:51 PM
120 Volt D.C. and 5 or 10 Amp. Variable Power Supply anurag The Projects Forum 14 06-05-2009 08:54 PM
6 Volt Power Supply from 12 volts (car battery) fuadramsey The Projects Forum 11 08-05-2008 10:31 AM
Power problem...but not the power supply. BiggerBean Computing and Networks 15 05-22-2008 10:35 PM
+-12 Volt Power Supply Howie The Projects Forum 30 04-02-2008 11:21 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
