All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-21-2008, 06:05 PM
Yash_Arya Yash_Arya is offline
Default A 3-bit and 4-bit binary adder.
Hello, I was trying to make a 4-bit binary Adder and I reffered to some sites here and there but I could'nt get my concepts clear.
Could anyone please tell me (show me?) how a circuit of a 4-bit binary adder would be? Using standard Gates and ICs only.
Also, how would it be different from a 3-bit adder?
Please help me with both the circuits, I will be greatful. If my question was not clear, ask me to clear it.
Thank you, Greetings.
Yash Arya.
  #2
Old 09-21-2008, 06:35 PM
scubasteve_911 scubasteve_911 is offline
Default
The 3 and 4-bit adders originate from a single bit adder, just scaled up.
The following link shows a single bit adder, then, how it is hooked up to make 4-bits.
http://www.play-hookey.com/digital/adder.html
I'm pretty sure that the logic isn't optimized for low-gate count, but it will work fine. It is possible to write out karnaugh maps or do boolean algebra to reduce the number of gates needed, but that's another level of complexity.
Steve
Or, an allaboutcircuits reference is here too
http://www.allaboutcircuits.com/vol_4/chpt_9/3.html
  #3
Old 09-21-2008, 06:36 PM
beenthere's Avatar
beenthere beenthere is offline
Default
Get the data sheet on a 74XX83. It is a 4 bit full adder. The data sheet should include the internal logic diagram.
__________________
First comes the hardware, then the software.
  #4
Old 09-23-2008, 02:02 AM
harsimranjit singh harsimranjit singh is offline
Send a message via Yahoo to harsimranjit singh Send a message via Skype™ to harsimranjit singh
Default
whats 3 and 4 bit adder////i mean binary
  #5
Old 09-23-2008, 02:28 AM
beenthere's Avatar
Default
A 3 bit adder adds 3 bit values, the 4 bit adder adds 4 bit values.
__________________
  #6
Old 09-23-2008, 12:39 PM
Default
Thank you for your help people, now I think I do not need any further guidance unless I myself read the resources that you kindly provided.
However, (obviously) if someone else needs to clear something, go right ahead.
Thank you,
Yash Arya.
  #7
Old 09-23-2008, 12:55 PM
Default
**I already have querries to be cleared**
I went through the page [http://www.play-hookey.com/digital/adder.html] you provided me and I have the following querries.
(1) In the Full-Adder part, if we see the truth table, We have A,B (i/p) and Cin, Cout. Here, Is A itself a multi-bit number (and same for B)? Or do A, B, Cin and Cout together make a "multi-bit number"?
(2)If, A is itself a multi bit number, then how come in the truth table we give it only "0" or "1" in its coloumn? I mean, the number will be something like "A = 1011" for example.
Please clear my Querries. Thanks a lot in advance.
Thank you,
Yash Arya.
  #8
Old 09-23-2008, 03:41 PM
veritas veritas is offline
Default
For each individual full adder, A and B are only 1 bit, and Cin/Cout are for those bits. For a multiple-bit adder, Cin goes to the least significant bit, and Cout comes from the most significant bit. The other carries are internal.
  #9
Old 09-23-2008, 06:26 PM
Default
Quote:
Okay, so let us speak in terms of "order" of 'A' and 'B'. Suppose that 'A' and 'B' are bits of order 'n'. (i.e A[n] and B[n]) and the carry from previous bit is C[n-1].
Now to add A[n], B[n] and C[n-1], we need one full adder. Am I correct? So, for 4-bit adder, will I need four such full-adders? (Heck that will be complex)
Also, let us say that after the Addition, I recieve Sum (Sn) and Carry out(Cn).
Now what all should be taken as i/p for the next full-adder?
From what I understood, It will be A[n+1], B[n+1], C[n].
Am I correct?
Also, please tell me some suitable IC for the same. (The ICs I have in my syllabus are 7432, 7408, 7404, 7402, 7400, 7486, 74135) The ICs must be from the list only.
Thank you all for your co-operation.
Yash Arya.
  #10
Old 09-23-2008, 06:57 PM
Default
You are correct on all counts, I believe. If you have only logic gates, you will need to create logic for Sum[n] and Cout[n] from the inputs A[n], B[n], and Cin[n], and then duplicate you logic 4 times.
*edit* I would suggest making a truth table.
Tags
Related Site Pages
Section Title
Worksheet Counters
Worksheet Binary math circuits
Worksheet Digital codes
Worksheet Numeration systems
Textbook A binary adder : Principles Of Digital Computing
Textbook Decoder : Combinational Logic Functions
Textbook A Full-Adder : Combinational Logic Functions
Textbook A Half-Adder : Combinational Logic Functions
Textbook Octal and hexadecimal numeration : Numeration Systems
Similar Threads
Thread Thread Starter Forum Replies Last Post
2 Level 16 bit Carry lookahead adder laguna92651 Homework Help 5 01-14-2012 04:22 PM
Binary subtraction Nabla General Electronics Chat 5 09-21-2008 05:15 PM
CMOS adder circuit sahila The Projects Forum 1 04-09-2008 02:02 PM
vhdl code 4 bit full adder using PAL. sruthi The Projects Forum 3 11-10-2007 01:18 PM
8-bit binary adder using two 7483s and 7seg displays JoeyB Homework Help 3 03-22-2007 03:37 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
