All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Computing and Networks
Notices
Computing and Networks Discussion forum for general computing technologies, personal computing, data networking, information technology, and computer systems engineering.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-28-2008, 06:07 PM
Mark44 Mark44 is offline
Default What causes a computer power supply to fail?
Over the past couple of months, my home computer has been acting up. During bootup the computer start sequence would fail, right after the drive started to spin up. I found that if I turned off the "hard" on/off switch at the back of the computer (the one that's on the power supply), and turned it back on, I could get the computer to start, and it would run without problems. The problem seemed to me to be a power supply that was failing, so I figured that I would need to replace it shortly.
The first time I noticed any problems was when I tried to restart the computer after it had been put in stand-by mode, so I stopped using stand-by and would shut it down instead. Recently, I have started noticing the problem during bootup.
Yesterday morning, I was unable to get the computer to start up, even after three or four attempts using the trick that had worked before. On the way to work I bought a new power supply, and when I got home, installed it. The computer now seems to be working as it should. This leads me to believe that the old power supply actually was the culprit.
I should add that the computer is about two years old, and is one that I put together from parts purchased at a chain computer/electronics store (Fry's). The old power supply was 350 W, which I believe was sufficient for the machine. The new one is 500 W (the place I got it had only one model).
My question is: What would have caused my old power supply to fail after what seems a relatively short time (about two years). The MTBF for the new one is 50,000 hours, which at the rate my wife and I use this computer should last us 50 to 100 years. I don't know anything about the internals of a power supply. What are the parts that can fail?
Thanks,
Mark
__________________
"The floggings will continue until morale improves!"
  #2
Old 08-28-2008, 07:32 PM
gerty gerty is online now
Default
A lot of power supply failures are heat related. Is your fan running?
Is the power supply full of dust or other debris? Is the computer in a cabinet with little or no air circulation?
  #3
Old 08-28-2008, 07:46 PM
bertus's Avatar
bertus bertus is online now
Administrator
Default
As gerty says heat is a great problem.
It can cause the capacitors to malfunction.
Also fast on and off switching of the powersupply could break it.
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #4
Old 08-28-2008, 07:59 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
One big cause of heat is allowing dust to accumulate in the computer.
About every three to six months, you should open up the case, and blow out the dust using dry compressed air, or those cans of compressed air you can buy at office supply stores. Don't allow the fans to be spun at high speed by the compressed air, as that can cause early bearing failure. However, try to get them as clean as possible. Use a wooden stick to keep them stationary while you're blowing on them.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #5
Old 08-28-2008, 08:47 PM
CVMichael CVMichael is offline
Default
I have a question about that too
I do that sometimes (to blow the dust off), but I'm afraid that the freezing liquid/thing that the can sprays damages the componenets ?
  #6
Old 08-28-2008, 08:59 PM
Default
By the way...
One time my power supply failed because of one of my hard-drives...
The hard-drive malfuntioned, and it was taking a lot of power plus my other hard-drives, the power supply could not keep up and refuzed to start.
To find out what was couzing the problem, I removed each hard-drive one by one, and started the computer with one HD off, then another one off, and so on... to find out the one with problem.
But it was too late for the power supply, it started to make weird noises, so I replaced both, HD and power supply (to a more powerful one also).
Anyways... sorry to intrude with my boring story...
  #7
Old 08-28-2008, 09:14 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Not just bearing failure, the counter EMF generated by the moving blade can blow the solid state electronics inside the fan. Been there, done that. It's a reliable way to take out a fan, so Wookie's advice is excellent.
Long time ago my Dad's computer started making noise, it was the power supply fan. I asked him to stop using it the moment it became quiet. Instead he kept on using it, burning out the motherboard, the hard drive, the hard drive interface (blew about 4 of those because the hard drive was bad, but looked good for all of a minute, until the interface card blew), and of course, the power supply. I asked him why he did this (after basically building a new computer from scratch), the answer was, "I thought it fixed itself.". DOH!
Power supplies are cheap, compared to the rest of the computer. Having said that, if the fan is the only problem I won't hesitate to only replace it (NOT for amateurs).
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #8
Old 08-28-2008, 09:25 PM
Default
Quote:
Yes, it was running. Besides the PS fan, there's one on the CPU and one of the fans in the computer case was hooked up (and presumably running).
I didn't open up the power supply, so don't know if it was full of dust. There was a small amount of dust on the fan blade itself, but very little inside the computer case. The computer is not in a cabinet, and there is nothing to block air intake to the fans.
__________________
  #9
Old 10-08-2008, 04:57 AM
ugierhia ugierhia is offline
Default
It has the isolation part,,, just check first the two IC there,, if it does not recieve supply from the primary, then it will not give output,,,, check for blotted capacitors,, it causes the output to drop or rise depending on the condition of the system.
  #10
Old 10-08-2008, 03:06 PM
chrissyp chrissyp is offline
Member
Default psu failure
Hi
All the above are right,but don't forget to clean out the air intake at the front of the tower if that gets blocked the fan will not work properly .If you are buying a new power supply ,buy one that is about 50% more power output than you need this will ensure it has an easy life,especially if your tower is in a confined space with poor airflow .
Tags
Related Site Pages
Section Title
Textbook Likely failures in proven systems : Troubleshooting -- Theory And Practice
Textbook ElectroStatic Discharge : Practical Analog Semiconductor Circuits
Worksheet Basic troubleshooting strategies
Textbook General troubleshooting tips : Troubleshooting -- Theory And Practice
Similar Threads
Thread Thread Starter Forum Replies Last Post
30-32volt 4A regulated dual power supply... excuseme The Projects Forum 15 01-10-2009 04:01 PM
7805 & 12VDC Power Supply Problem JDC The Projects Forum 10 10-24-2008 06:09 AM
Power problem...but not the power supply. BiggerBean Computing and Networks 15 05-22-2008 10:35 PM
Uninterruptble Power Supply (UPS) Fail/ Faulty... kengloong General Electronics Chat 5 12-12-2005 04:57 PM
computer power supply cooling fan? terrakota Homework Help 9 02-13-2005 11:34 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
