All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-22-2008, 03:07 PM
rp_1 rp_1 is offline
Default Differential amplifier problem
I'm using an opamp as a differential amplifier. I have trouble figuring out the problem. So i need your help.I have attached the circuit- Fig 1. The gain is 100. V1 is supplied from a potentiometer which is 0V to 10V. I want the V2 to detect the voltage output from a transistor source pin.
I have kept the gate voltage at 0V. So the transistor is OFF and no voltage should be present at the SOURCE pin.
But when i change the V1 voltage (non inverting input) from 0V to 10V, i see the same voltage 0V to 10V at the source pin eventhough the transistor is OFF. I checked to see whether the transistor is bad but it is fine. I verified it with a diode (Fig 2) between SOURCE pin of the transistor and V2. Now i tested it again with 0V to 10V at V1. I did not see any voltage at source pin of the transistor. But i do see same voltage (0V to 10V) at V2.
I dont understand why there is 0V to 10V at V2 when it should read only 0V from Source pin of the transistor. Could someone please help me.
Thanks,
RP
  #2
Old 08-22-2008, 03:19 PM
mik3's Avatar
mik3 mik3 is offline
Default
Is it a p or n channel FET?
  #3
Old 08-22-2008, 03:21 PM
Default
I'm sorry tht i didnt mention it. Its an NFET.
  #4
Old 08-22-2008, 03:23 PM
beenthere's Avatar
beenthere beenthere is offline
Default
Your op amp can't see a difference voltage. The output voltage is fed back to the summing junction through either the 100K resistor, or the FET and 1K resistor. The gain will always be 1.
To make the op amp into a follower with gain, connect the source lead of the FET to ground and the drain to the end of the 1K resistor. That will give you your gain of 100 when it is turned on. With lower conduction, the gain will reduce.
__________________
First comes the hardware, then the software.
  #5
Old 08-22-2008, 04:03 PM
Default
Now i understand the voltage at V2. Thank you.
The circuit in the attachment is only a part of the whole design. I chopped the gate part off from the original circuit. The transistor source is the system output for the entire design. So the source cannot be grounded. Are there any other possibility?
Thanks,
RP
  #6
Old 08-22-2008, 05:33 PM
Audioguru Audioguru is offline
Banned
Default
Negative feedback causes the voltages at both inputs of an opamp to be the same unless its output is clipping or its input voltage is too high or too low.
  #7
Old 08-25-2008, 12:26 PM
Default
If i dont use a negative feedback, then the circuit is similar to using a comparator but there will be only 2 output states either High(+VCC) or Low(Gnd) which means no linear region of operation and there is no gain limitation.
  #8
Old 08-25-2008, 01:26 PM
beenthere's Avatar
Default
If you want comparator action, then use a comparator like an LM311. If you are running the op amp on a positive voltage and ground, then the op amp will not be able to swing the output all the way to ground, unless you are using a rail-to-rail device.
All devices have a gain limitation. There is always a measurable transition between one state and the next.
__________________
Tags
Related Site Pages
Section Title
Worksheet Differential transistor amplifiers
Textbook Computational circuits : Practical Analog Semiconductor Circuits
Textbook Practical considerations : Operational Amplifiers
Textbook Single-ended and differential amplifiers : Operational Amplifiers
Video Lecture Linear Transistor Applications - Transistors and Transistor Circuits
Textbook Depletion-type IGFETs : Insulated-gate Field-effect Transistors
Textbook Active-mode operation : Junction Field-effect Transistors
Textbook Biasing techniques : Bipolar Junction Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Differential amplifier : Discrete Semiconductor Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Modeling op-amp as a differential amplifier Gtofig The Projects Forum 2 01-16-2008 02:05 PM
Sony amplifier problem Nick_G General Electronics Chat 11 09-04-2007 10:19 AM
Differential Amplifier dhpatil General Electronics Chat 9 06-19-2007 01:26 PM
differential amplifier project boby4u The Projects Forum 17 06-10-2007 05:10 PM
My PC amplifier problem....? k41 The Projects Forum 2 12-15-2006 06:07 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
