All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Computing and Networks
Computing and Networks Discussion forum for general computing technologies, personal computing, data networking, information technology, and computer systems engineering.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-20-2008, 02:40 AM
Externet's Avatar
Externet Externet is offline
Question How to install programs onto a CD RW ?
Hello all.
I have very poor skills using compfusers and would like to know how to install antivirus program(s) I have on CD (Symantec, Norton, or downloaded Lavasoft Adaware) onto a rewritable CD instead of installing onto hard drive; making it a 'live' - bootable - autoexecutable, to be used with a friend's sick WinXP (He believes I know about these things... , he knows even less than I )
The intention is to boot from such CD and get the option to run one of its burned antivirus executable programs before Windows starts.
I understand the updating of virus definitions may not be possible if the CD is a plain one not rewrittable; and it may be possible to update if rewrittable. The execution / access speed is of no concern.
As I run Linux, I believe I would have to follow your instructions on a healthy WinXP compfuser, right ?
Thanks,
Miguel
__________________
Abolish the deciBel !
  #2
Old 08-20-2008, 02:58 AM
beenthere's Avatar
beenthere beenthere is offline
Super Moderator
Default
You may have to download "the ultimatebootcd" (Google will find that name) and burn the .iso image onto a cd or flash drive. It has the tools to do the cleaning.
An alternative is to install AVG Free and run it. Then, even if some of the OS files are damaged, you can select a restore point on a date prior to the virus infection to clean up the computer.
None of the programs you mention will run without the XP OS loaded, so burning any or all to a bootable cd as stand-alone executables won't work. They have to be in the registry and work with it to run. Cleaning up computers is never easy. Saving personal data onto a flash drive and resysteming the computer may be the easiest way out. Hopefully, he has system restore disks.
__________________
First comes the hardware, then the software.
  #3
Old 08-20-2008, 09:30 AM
Dave's Avatar
Dave Dave is offline
Administrator
Default
Quote:
Originally Posted by Externet View Post
Hello all.
Thanks,
Miguel
I don't think the said programs will allow you to run them outside of Windows because there are more than just the application files and signatures - settings are strewn across the registry and there are other miscellaneous files. You would need to get dedicated non-install versions of the said software.
Failing getting dedicated versions, the closest you will probably get is to install the apps as per normal and then running them in Safe Mode:
  • Install and update the AV applications
  • Reboot the OS
  • When the BIOS screen appears repeatedly tap F8
  • Select the Boot to Safe Mode option (inc. networking of you want net access)
Safe Mode is the bare OS so is pretty slow, however it will allow you to run the said applications with minimal interference.
Another option is to download the free version of Avast! When you install Avast! it updates then prompts you to reboot the OS asking would you like to perform a start-up scan - this scan will scan the whole system before the OS boots.
Dave
__________________
"If I have seen further, it is by standing on the shoulders of giants" - Sir Isaac Newton
  #4
Old 08-21-2008, 09:42 AM
cumesoftware's Avatar
cumesoftware cumesoftware is offline
Default
I would not recommend installing an AV program directly in an infected computer (with or without safe mode), because you risk to infect the newly installed AV as well. Dave mentioned Avast, which is an excellent AV program (I have it myself), and has plenty of updates.
However, I recommend you to download both Avast Virus Cleaner, and full featured Avast Home Edition. They are both free. Before installing Avast Home Edition, you should run Avast Virus Cleaner in order to clean the computer first. The application can be run directly from a CD without installation, and scans the memory as well. Only then you should install Avast Home Edition. Thus you will minimize the risk of compromising your AV.
Note that Avast Home Edition requires registration (in a year basis), but registrations and renewals are free and it is only a question of asking for a new key via e-mail.
__________________
I love the smell of toasted transistors in the morning.
  #5
Old 08-21-2008, 12:24 PM
jpanhalt jpanhalt is online now
E-book Developer
Default
Let me make it unanimous. I have been using Avast for more than 2 years. I had tried previously Kaspersky, Norton, and McAfee. Besides being free, Avast does not noticeably slow down the computer, except just a little while it is doing updates in the background.
John
Edit: BTW, if your friend had McAfee and you or s/he removed it, that may be part of the problem. I have crashed and had to wipe, reformat, and rebuild the hard drive on each of 3 computers from which I removed McAfee. The so-called removal tool on the McAfee site corrupted the registry. McAfee was zero help in fixing the problem.
  #6
Old 08-21-2008, 12:32 PM
studiot's Avatar
studiot studiot is offline
E-book Developer
Default
You will need to format the RW CD as if it were a normal CD to get things to run from it, before placing any programs on it.
You can then erase it afterwards.
The Symantec (Norton) will not work without product activation, so will be of no use to you. However some versions come with a ready bootable recovery CD, from which you can run the Norton. You can also copy the latest updates to a usb stick from your good pc and point the Norton to use this instead of the older definitions on the CD.
Avast is very good, but does not cope with spyware. To clean this download mbam from
www.malwarebytes.org
as a trial.
  #7
Old 08-21-2008, 04:10 PM
Externet's Avatar
Default
Thanks.
beenthere: No recover disks; I tried to make them and the infected compfuser vomits them, halts and does not allow to do it.
So far I have rescued about 3000 pictures and audio files onto a second SATA drive I temporarily hooked in there. Happy so far, but the crippling has not been tackled yet. His kids really messed up by frequenting / downloading games and half a dozen antivirus programs that actually aren't. They are advertisements periodically faking scan and reports peddling for money. The worst is one titled something like XP cleaner2008, showing every 5 minutes.
Dave; cumesoftware
I will try Avast, will proceed slowly, as barely know what am doing and do not want to make it worse.
studiot, now you hit me with a baseball bat on my head. Never knew a CD RW could have a choice of how to format it. And still don't know how to. The rewrittable feature choice was meant to be updateable for new virus definitions, not to care about erasing it.
All this may well be beyond my skills. But not much to lose by trying at this point. Trying to follow these instructions is painful enough for me:
http://www.articlesbase.com/security...cd-380611.html
http://ubcd4win.com/howto.htm
Miguel
__________________
  #8
Old 08-21-2008, 04:26 PM
beenthere's Avatar
Super Moderator
Default
In case you want to pursue the recovery disks, the computer should boot off the one with the OS. The level of OS off that disk should be about like DOS, and it should allow you to format the hard drive - scrub all data off and prepare it for the reinstall of the OS and other software.
Note - it helps to read. You were trying to make the disks from the computer. I suppose that the stuff is on the D partition, and the virus can easily prevent access to anything.
If the virus can prevent the recovery disk production, you may have to remove the hard drive and bury it at a crossroads with a stake driven through its platter. Or take the computer to a storefront business where they do such stuff.
Children should never have access to a computer connected to the internet without supervision. Bad things always happen. Some children are surprisingly old. Computers in the internet should never operate without all the updates and effective anti-virus like AVG. Spybot is invaluable (and free) for blocking spyware and such.
__________________
  #9
Old 08-21-2008, 05:18 PM
studiot's Avatar
E-book Developer
Default
Beware beware beware
Spybot is really bad news. It is extreme malware.
There is a good program called 'spybot search and destroy' which is the one you want.
There is a site which tests and lists antimalware, good and bad.
http://www.spywarewarrior.com/rogue_anti-spyware.htm
Check there in future before downloading anything.
Your best bet is to use the web's premier free malware removal service at Major ~Geeks. Start here.
http://forums.majorgeeks.com/showthread.php?t=35407
  #10
Old 08-21-2008, 06:21 PM
beenthere's Avatar
Super Moderator
Default
Good info to have - I only was aware of the Spybot Search and Destroy program. It figures that some slime would pick an easily-confused name for his crud.
__________________
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Which Schematic Programs? snarf Electronics Resources 32 03-03-2009 03:36 PM
Social Programs chesart1 Off-Topic 27 11-16-2007 04:09 PM
Synchronizing the two programs. Khan Programmer's Corner 2 09-24-2005 09:53 AM
Qbasic programs n9xv Programmer's Corner 12 01-30-2005 02:14 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Copyright © 2009, All About Circuits. All Rights Reserved.
