All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-18-2008, 08:01 AM
Ehsan Ullah Ehsan Ullah is offline
Default Equivalent Circuit for Transistor
Is there any equivalent circuit for a pnp or npn transistor which we can use to analysis the transistor circuit ?
Is it the same for all configration or it is different for each like a different circuit of common Base (CB ) and a different one for Common Emitter (CE)
  #2
Old 08-18-2008, 01:35 PM
mik3's Avatar
mik3 mik3 is offline
Default
Two famous transistor models are the H-parameters model and the R-parameters model. Search for them in google or wikipedia to see how do you use them.
  #3
Old 08-19-2008, 02:58 PM
Dave Dave is offline
Default
You should look up the general subject of "Small Signal Analysis", under which the models mentioned by mik3 will fall under.
See the following as was posted by a FM in another thread: http://users.ece.gatech.edu/~mleach/...et/thejfet.pdf
Dave
  #4
Old 08-23-2008, 05:40 AM
Default
Thank you very much for helping me.
Tags
Related Site Pages
Section Title
Worksheet Differential transistor amplifiers
Worksheet Switched capacitor circuitry
Worksheet Class B BJT amplifiers
Worksheet Class A BJT amplifiers
Worksheet Bipolar junction transistors in active mode
Worksheet Th'evenin's, Norton's, and Maximum Power Transfer theorems
Worksheet Series-parallel combination AC circuits
Textbook CMOS 555 LONG DURATION BLUE LED FLASHER : 555 Timer Circuits
Textbook Class B audio amplifier : Analog Integrated Circuits
Textbook The common-collector amplifier : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Thevenin's Equivalent Circuit wheeltiger Homework Help 4 09-10-2009 01:00 PM
Finding the Equivalent Resistance of a Circuit wiz0r Homework Help 11 05-07-2008 12:01 AM
BJT - Small Signal Equivalent Circuit VVS Homework Help 3 02-15-2008 11:17 PM
equivalent circuit of a alternator and starter kalyani82 General Electronics Chat 1 12-13-2006 05:55 AM
Sensor circuit, Flasher circuit 123456 Homework Help 11 08-03-2006 10:58 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
