All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-17-2008, 01:52 PM
elinque elinque is offline
Default Barcode Scanner (Line Reader) Circuit Diagram
anyone has this circuit diagram?? i need it for school project yet couldn't find..
  #2
Old 08-17-2008, 03:13 PM
kammenos kammenos is offline
Default
What diagrmam? The whole scanner? Where do you go to school? What kind of school wants a barcode scanner circuit for project 8|
  #3
Old 08-17-2008, 06:09 PM
beenthere's Avatar
beenthere beenthere is offline
Default
There is no one way to do the scanning. See this link - http://www.denso-wave.com/en/adcd/fu...e/scanner.html.
There is also more than one way to decode the results of the scan. You might wish to become more familiar with the subject and come back with more focused questions.
__________________
First comes the hardware, then the software.
  #4
Old 08-19-2008, 04:20 PM
Default
Can the CCD method works far range??? if so, can anyone provides me with a circuit diagram of the barcode scanner circuit diagram?
  #5
Old 08-19-2008, 04:37 PM
CVMichael CVMichael is offline
Default
At my previous job I had to use barcode scanners. I used CCD and also laser scanner.
CCD is for short range, 1-2 inch, and it's limited to the size of the barcode also, i.e. if the barcode is printed on a full page (very big), there is no way you can scan it with a CCD scanner. Laser is much farther, I think I scanned from as far as 2 feet, and the size of the barcode it does not matter that much, if it's big, you just scan from further away then normal.
I think laser is faster too... with CCD you have to move it around to get the right position until it scans, but with laser, you just point anywhere on the barcode, and it scans right away...
I always hated to use CCD scanners becuase of it's limitations.
But if you DO find a circuit diagram for a CCD scanner, I would be very interested to see it because I want to use CCD for something else, and I have no idea how to read the information from the CCD array.
  #6
bertus's Avatar
bertus bertus is offline
Super Moderator
Default
For more information on barcodes and their readers take a look at the links of this page.
http://www.educypedia.be/electronics/databarcode.htm
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #7
Old 08-19-2008, 04:39 PM
Default
can anyone provides me a with CCD and laser scanner circuit???? thanks a lot.. i need it very much..
  #8
Old 08-19-2008, 04:55 PM
Default
Well, if you can figure out how to read the data from the CCD array into a microcontroller, then the rest is easy... then it's just a matter of programming the microcontroller, and that is easy for me (since I am a programmer).
[Edit](to continue my sentance)
.... and I could write the code for you to read the barcode if you don't know how.
By the way... what barcodes do you plan to read ? Code 2 of 5, Code128, Code39, etc. ? (I only have experience in Code128)
  #9
Old 08-20-2008, 12:37 PM
Default
i'm just planning to do a simple project for the school. the barcode would be scanned. example, bus 31. meaning code 31?? is that right?
yeah, i do need help in programming. i'm planning to do a barcode scanner. and a barcode . when the barcode scanner scan the barcode, it would send a signal for it to sound out the number , "Bus 31"
  #10
Old 08-20-2008, 12:49 PM
Default
Quote:
It is not only a circuit. Is a whole project with circuit AND programming. It will not be so easy
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Problem with reading a circuit diagram zuse2000 Homework Help 8 06-17-2009 01:03 PM
circuit diagram to breadboard mauvehead General Electronics Chat 12 01-25-2008 05:06 AM
Circuit diagram Ameer Homework Help 1 11-30-2006 12:00 PM
UV flame scanner bulb used as safety-need circuit help Rezaxis The Projects Forum 2 09-03-2006 07:44 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
