Dear All
Here is useful project.
Time delay switch for mobile chargers:
Most of the mobile phone batteries can be fully charged within 2 Hours of time. This circuit is useful especially night time. Before going for sleep, we can put the charger on and go for sleep. Don t worry about over charging, this circuit will switch off the charger after 2 Hour. This is a simple monostable multi vibrator, which will switch on the circuit for a particular time period. When the circuit is in standby mode, transistor Q1 does not conduct, since its base is floating. When the switch( SW1 ) is pressed and current flows through R5 and the switch to provide positive bias to transistor Q1. Transistor Q1 conducts and its collector voltage drops, which acts as a negative trigger input for the monostable. Here a pulse will be generated 7200 second duration ( 2 hour ). See the attachment.
