All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-11-2008, 07:02 AM
varsity_villain varsity_villain is offline
Default Hydrogen Gas Sensor Circuit
Hi all,
I wan to design an analog circuit which can detect the concentration of the hydrogen and display it in LCD. the idea of the circuit is, it will detect an input from a gas sensor and the input will be used to calculate the concentration of the gas and will show the output in LCD.
So i need to design the circuit where it can detect the input from sensor. I dnt know how to start design the circuit. Anyone can help on this?? Any suggested analog circuit diagram???
realy need ur help guyz....
  #2
Old 08-11-2008, 09:14 AM
jpanhalt jpanhalt is offline
E-book Developer
Default
Is the hydrogen mixed with other gases? Which gases? What concentrations of hydrogen do you need to detect? What pressures?
In other words, you need to give more information about the conditions in which it will be operating.
Have you done any search yourself for information? Commercial units are readily available. Here and here are just two of many found under "hydrogen detector."
Also, Wikipedia has a nice article on hydrogen detection.
What is your level of experience in electronics and microcontroller programming?
John
  #3
Old 08-17-2008, 01:40 AM
kender kender is offline
Location: SF Bay Peninsula, California, Planet Earth, Solar System, Milky Way
Send a message via MSN to kender Send a message via Yahoo to kender
Default
Quote:
If you've identified the sensor, whose output you need to measure, could you post a link to its datasheet? To help you design a circuit, we need to know the sensor that you have.
__________________
Read the label, before opening a can of worms.
  #4
Old 08-17-2008, 07:54 AM
kammenos kammenos is offline
Default
Sensor -> microcontroller -> LCD...
Simple answer for simple question. Please be more specific
  #5
Old 09-03-2008, 06:02 PM
Default
The idea of the design is
sensor > analog circuit > lcd
analog circuit:
input > integrator stage > comparator stage > output
so i have to design the analog circuit with the idea given to me. the sensor should only detect hydrogen gas and send the input as voltage to analog circuit. since the sensor will be fabricated by another group so i dont know the datasheet of the sensor. Basically the sensor is fabricated using SnO2 material. So any suggestion on how i can start design the analog circuit???
  #6
Old 09-03-2008, 07:12 PM
blocco a spirale blocco a spirale is offline
Default
You've got to know the specs of the sensor.
What output voltage range are we looking at? microvolts? Volts? offset? How does the output relate to the concentration of gas?
  #7
Old 09-04-2008, 02:16 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
If you at least know the required range of your display, you can work on a display driver. Once the stats on the sensor are available, you can design the signal conditioner.
If you don't know the required range of the display, you'll be able to work on something else entirely until your other group can give you some numbers.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #8
Old 11-12-2008, 06:33 AM
Default
hi,
is there anyone can suggest any circuit that i can construct to test the concentration of the hydrogen?? so far i found a light integrator circuit as my reference. do u think i can use light integrator circuit diagram to construct hydrogen circuit???
after had discussion with the group who will fabricate the hydrogen sensor, they said the output which can be produce from sensor is in mvolt or micro volt. so they wan my analog circuit can amplify the output and determine the concentration.
how i can construct the circuit?? from my understanding, i think i can use op-amp 741 as integrator and as a comparator. i juz dont understand how i wan use the op-amp with other components to came out with the analog circuit.
from,
confused...
  #9
Old 11-12-2008, 01:07 PM
Super Moderator
Default
The 741 is a relatively old amp. You may be disappointed with its performance.
If you want a dual supply op amp, consider the TL084. If you want a single supply op amp, consider the OPA377.
Many other choices are available as well.
This might be of help: http://www.allaboutcircuits.com/vol_3/chpt_8/index.html
__________________
- Michael Faraday
  #10
Old 11-15-2008, 01:52 PM
Default
ok, if i wan to construct the circuit i need a reference. can u suggest any circuit diagram or tutorial were i can learn to build the analog circuit. i dont know from where to start. any suggestion please?
Tags
Related Site Pages
Section Title
Worksheet Linear computational circuitry
Textbook Ionization (gas-filled) tubes : Electron Tubes
Textbook Computational circuits : Practical Analog Semiconductor Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Practical considerations : Batteries And Power Systems
Textbook Special-purpose batteries : Batteries And Power Systems
Textbook pH measurement : Electrical Instrumentation Signals
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fuel of the Future: Water, is it a myth or legend? linchiek Off-Topic 114 10-25-2009 12:51 AM
Hydrogen engine ignition delay ChrisHelvey The Projects Forum 10 08-28-2008 11:40 PM
Hydrogen Torches jpanhalt The Projects Forum 15 08-28-2008 02:13 PM
Gas Powered Battery Chrager Progress pntrbl The Projects Forum 12 06-12-2008 05:41 AM
Hydrogen William Baker The Projects Forum 2 05-31-2008 02:58 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
