Hi Lee,I have very basic electronic skills but need a circuit that will operate a relay every time a 12v car ignition coils sparks, the spark rate of the coil is once every 2 seconds.
I've attached a schematic of the system, the solenoids have a fill time of 1second & then switch off, the coil is triggered 20ms after this..OK - does the electronic trigger for the ignition coil apply a momentary ground (earth) to one side of the coil, and the other side of the coil is hooked to 12v?
by Aaron Carman
by Jerry Twomey
by Duane Benson
