All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-08-2008, 03:01 AM
kender kender is offline
Location: SF Bay Peninsula, California, Planet Earth, Solar System, Milky Way
Send a message via MSN to kender Send a message via Yahoo to kender
Question High voltage nanosecond pulse generator
Colleagues,
Could anyone suggest a schematics or a reference for a high voltage pulse generator? I need a 500V pulse 10ns long or sorter. Negative spike from 500V to 0 and back to 500V would work. I have a schematic for an old (1977) pulser, but the SCR that's used there has been discontinued. I know how to generate a nanosecond pulse at the logic levels. But what would be a good topology for the high voltage "switch"? MOSFETs have gate capacitance that needs to be charged within a few nanoseconds. SCRs (which I, unfortunately, don't have experience with) have their own problems too.
Enlightenment will be appreciated!
- Nick
__________________
Read the label, before opening a can of worms.
  #2
Old 08-08-2008, 03:45 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Sounds like you may be looking for IGBT's.
http://en.wikipedia.org/wiki/IGBT
http://www.powerdesigners.com/InfoWe...BTs/igbts.shtm
http://www.st.com/stonline/products/...gbts/igbts.htm
They aren't a complete circuit - this is just an introduction to a relatively new type of device.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #3
Old 08-08-2008, 04:08 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
What sort of load do you need to drive with this pulse?
  #4
Old 08-08-2008, 04:39 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
How about a spark gap?
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #5
Old 08-08-2008, 07:41 AM
Default
Quote:
Thanks for this tip! I'll look into IGBTs.
Quote:
The load is going to be an ultrasonic transducer. 50 to 300 Ohms with some capacitance to it. I don't have a datasheet for the transducer at the moment, but I will know what the load is soon.
Quote:
I don't know how. I wish I knew.
__________________
  #6
Old 08-08-2008, 06:23 PM
Ron H's Avatar
E-book Developer
Default
You need to consider the transient (capacitive) current requirements as well the resistive load. Remember I=C*dv/dt. If you need 5ns rise and fall times into 100pF, for example, that's a peak current requirement of 10 amps. Not trivial. If all the capacitance is in series with the resistance, then you just need to consider the resistive component.
  #7
Old 08-09-2008, 06:32 PM
Default Load impedance
I've clarified what the load is going to be. 50 Ohms.
My plan is to charge a large capacitance from a relatively small power high voltage supply. Then this capacitance will fulfill the peak current requirements.
__________________
  #8
Old 08-09-2008, 07:16 PM
SgtWookie's Avatar
Expert Member
Default
Thingmaker3's spark gap suggestion might be the easiest (and cheapest) solution.
It's generally accepted that 3,000,000 volts are required to jump an air gap of 1 meter near sea level.
This translates to 76.2v per mil (0.001"). So, a spark gap of .0065" (rounded) should cause the 500v supply to ionize and jump the gap at right around 495v. The duration of the spark would then depend on your load impedance and the size of your capacitor.
__________________
General info:
  #9
Old 08-10-2008, 08:01 AM
nanovate nanovate is offline
Default
You can also buy a GDT (gas discharge tube) or look at a MCT device.
  #10
Old 04-26-2009, 05:26 PM
Ruptor Ruptor is offline
Junior Member
Default
Hi
I know this thread is old but I just saw this circuit and thought it might help others to build a more modern version of a nano pulser.
http://www.case.edu/cse/eche/ESA2008_Proceedings/H3.pdf
Incidently using gas breakdown in a spark gap requires that the gas breakdown voltage be exceeded it doesn't matter what the gap is to start with the voltage has to exceed Vbrk. Reducing a gap does not make it break down at a lower potential.
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
High Voltage Low Current SoundGuy General Electronics Chat 12 11-05-2009 12:21 PM
Wind generator Voltage controller kronk The Projects Forum 7 01-13-2009 08:22 AM
High Voltage MOSFET Drivers ams0178 The Projects Forum 14 08-16-2008 04:25 AM
Electric fence - High voltage arcing problem... byrona General Electronics Chat 4 09-22-2007 12:01 AM
Low Voltage pulse generator help simon Homework Help 1 05-19-2004 04:17 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
