| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
we been asked to design a simple electronic wattmeter on the breadboard which measures true power, apparent pwer, rms current,rms voltage & power factor. im lookin for a simple schematic of the wattmeter circuit....to be used, this has to measure current and voltage separately and a code will be written on matlab to achieve the measurent of power, serial comms or an LCD will be used to display the measured values, microcontroller used will be the ATMega16!
#2
Atmel actual has a "Application note" for a power/energy meter. The one they made is for 220v and 10A, but they say it can be adjusted for any voltage/current.
Its a very good document! They show all formulas and explain every part in detail. Actualy I have asked a similar question here Here are the links: Pic based power meter It could be fixed for an avr. Simple digital AC wattmeter 1v/1000w Optoisolators compute watts and volt-amperes Last edited by arthur92710; 08-08-2008 at 01:48 AM. Reason: Added info |
#3
thanks a million arthur!
#4
No problem.
![]() But their is a much simpler way to do it. (It might have some problems) If you have a load like a light bulb, take a small value resistor (1 or .1 ohm) and put it between the bulb and the nutral wire. Then measure the voltage accross the resistor. Here is a simulation video. Just give it a few seconds to load. |
#5
Well the problem with the simpler resister circuit is that its not linear. I tried to fix it but cant. One of the other guys can help with that.
| Tags |
| circuit, wattmeter |
Related Site Pages
| Section | Title | |||
| Video Lecture | Transformers (Part 2) - Analysis of Transformer Circuits - Inductors,Capacitors,Transformers | |||
| Worksheet | Design Project: Dual-output AC-DC power supply | |||
| Worksheet | Design Project: AC-DC power supply | |||
| Worksheet | AC metrology | |||
| Worksheet | Peak, average, and RMS measurements | |||
| Textbook | AC voltmeters and ammeters : Ac Metering Circuits | |||
| Textbook | Practical power factor correction : Power Factor | |||
| Textbook | Simple AC circuit calculations : Basic Ac Theory | |||
| Textbook | Measurements of AC magnitude : Basic Ac Theory | |||
| Textbook | Wattmeter design : Dc Metering Circuits | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Total Resistence in Parallel circuit | AWSariti | General Electronics Chat | 14 | 02-27-2009 11:44 AM |
| Automatic Light Circuit For My Car | tonysticks | General Electronics Chat | 16 | 06-26-2008 07:29 PM |
| Help with "noise" in Time Delay Circuit | Newbee | The Projects Forum | 7 | 06-11-2008 06:15 AM |
| Inductive Circuit Current Growth | Tommy | Homework Help | 6 | 03-28-2008 08:43 AM |
| Sensor circuit, Flasher circuit | 123456 | Homework Help | 11 | 08-03-2006 10:58 AM |
| Thread Tools | |
| Display Modes | |
