All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-05-2008, 11:36 AM
anurag anurag is offline
Exclamation 120 Volt D.C. and 5 or 10 Amp. Variable Power Supply
Hello members of allaboutcircuit.com forum.i am in urgent requirement of design of 120 Volt D.C. and 5 or 10 Amp. Variable (0 to 120V) Power Supply. but i couldnt figure out which components i should use for this , i searched various websites but i could not get anyone fulfilling the criteria.may i use multiple circuits of lm 317(or any other power ics) in series to get this higher voltage. i already have a 0 to 64volt Variable 5 Amp dual power supply and i test it with load by connecting both the supplies in series just like a cell or transformer it works well, i communicated to the customer service of the supplier of the power supply in this regard but they told that it is harmful, and any damage will not be considered in warranty, hence i stop the practise.kindly suggest your opinionThanksanurag
  #2
Old 08-05-2008, 03:52 PM
Tahmid's Avatar
Tahmid Tahmid is offline
Location: Cornell University, Ithaca, New York, USA (from Dhaka, Bangladesh)
Post
Hi Anurag,
I think you want a linear variable power supply with 0-120v dc and 10A power rating. It is not very difficult but very tricky. For that, you require a large transformer (2000va rating minimum), one bridge rectifier-gbpc3506(35A, 600v) with huge heatsink, 15000uF 250v(minimum) and 1uF non polar 250v(minimum) capacitors, one lm317 with heatsink, 10 nos. mjl21194 (250v 16a 200w each) npn pass transistors, with huge heatsinks, to increase the current capability, a potentiometer, some decoupling capacitors, few resistors, optional led indicators etc. You must provide appropriate fuses at the input and output.
If you require the schematic, I can provide you.
Thanks.
__________________
পৃথিবীর সর্বোচ্চ দালানও প্রথম ইট বসানো থেকেই তৈরি হয়েছে।
The tallest building in the world starts from the first brick.
  #3
Old 08-06-2008, 08:59 AM
Smile
Thank you Tahmid pls give me schematic
  #4
Old 08-09-2008, 07:07 AM
RmACK RmACK is offline
Member
Default
Does it have to be a linear supply? For such high power it's going to make a lot of heat!
__________________
I've started putting up some of my electronics projects on my website at electronics.rory.co.nz
  #5
Old 08-09-2008, 07:24 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
An LM317 would not really be suitable for such high voltage. It's limited to 40V.
A Texas Instruments TL783 goes from 1.2v up to 125V out, 800mA. Power dissipation would be very high at low output voltages. You would need a huge heatsink.
Better to have a switching or buck/boost preregulator and a linear postregulator. You'd save a lot on your air conditioning bill.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #6
Old 08-09-2008, 07:22 PM
Tahmid's Avatar
Post
Hi Anurag,
In my mentioned circuit, LM 317 will be used only to trigger the pass transistors and to obtain the regulated voltage and hence it is safe and sound for your requirement. In LM 317 the input and output difference is 40v, not 0 to 40v. So, you can get your required voltage and amperage with the help of a LM317 and other parts as I have mentioned. I will provide you the circuit tomorrow. Linear circuit is easier to make in comparison with smps. So, you can try. You can try with TL783 also,which I did not use.
Thanks.
__________________
  #7
Old 08-09-2008, 07:42 PM
cumesoftware's Avatar
cumesoftware cumesoftware is offline
Default
Quote:
Originally Posted by Tahmid View Post
Hi Anurag,
Thanks.
Well, the fact is that your LM317 still has to withstand more than 120V in order to regulate. The pass transistor works more like an emitter follower, and thus doesn't prevent the LM317 from burning. It is just not safe to submit a LM317 to a voltage greater than 40V, and I guess it will burn.
Plus, you still need a huge heatsink attached to your pass transistor, since your pass transistor is doing all the work. You have a better chance on controlling the voltage by the means of pulse with modulation, because a transistor in its active region dissipates a lot more heat than a transistor used as a switch. A switched-mode power supply would be your best bet, both in terms of cost, weight, volume and dissipated heat (and, of course, efficiency).
You can see the advantages of a switched-mode power supply, when compared to a linear one, on this wikipedia article:
http://en.wikipedia.org/wiki/Switched-mode_power_supply
__________________
I love the smell of toasted transistors in the morning.
  #8
Old 08-09-2008, 10:25 PM
Tahmid's Avatar
Post
I actually don't use linear power supply. I made and use smps power supply. But making SMPS power supply is not easy and hence I put the suggestion to Anurag, whom I think a newcomer in this field.
LM 317 will not be burned as it will not consume more than few miliA current, just to trigger the pass transistors and almost all the current will pass through the pass transistors bypassing LM317 and as long as input output difference is 40 volt,LM317 is safe(with minimum current).
This is a suggestion and a practical one. One can try and learn valuable lesson. Regarding heat sink- linear curcuits require huge heatsink and anybody trying with linear power supply should cope up with it.
For Anurag,
I will provide the circuit as early as possible. You can try and if you are confident, you can try smps route also. Linear power supply is bulky, weighty, big with huge heatsink etc.and costly but very reliable and also more lasting than smps.
Thanks.
__________________
  #9
Old 08-10-2008, 07:10 PM
Default
Not burned because of excess of current, but because of voltage excess between the input and ground pins.
__________________
  #10
Old 08-10-2008, 09:53 PM
Member
Default
Let's see his schematic before criticising too harshly, he may have a clever way to ensure that the 40V rating is not exceeded. Hear the guy out he said the schematic would be up soon...
__________________
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
6 Volt Power Supply from 12 volts (car battery) fuadramsey The Projects Forum 11 08-05-2008 10:31 AM
Recommendation for good variable power supply? nizee General Electronics Chat 1 08-01-2008 08:36 PM
Power problem...but not the power supply. BiggerBean Computing and Networks 15 05-22-2008 10:35 PM
+-12 Volt Power Supply Howie The Projects Forum 30 04-02-2008 11:21 AM
Charging batteries with a variable power supply Jacquesl General Electronics Chat 7 04-12-2007 09:28 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
