All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-30-2008, 05:52 AM
adeel adeel is offline
Junior Member
Question ups using oscillator ic cd 4047 THD PROBLEM
HI,
Friends . i have a ups which uses oscillator ic cd4047 which gets its power supplied 9 volts ic 7809. from out put of ic which are pin 10 and 11 separate reisistor of value 4.7 are used and after that signal is amplified by transistor d313 which has two big resistor of value 150R and 1k (5 waats). now signal enters a 2.2K resistor after that it goes to fet (irf3710) gate. now problem if when i run fan on this ups fan move slowbut when i check voltage from digital voltmeter they are 240 -250 ( for 220 volts fan) ups is of 500 watts. i am surprised what is going on. i think there is very high thd in the out put of ups . i want to decrease the thd i think it is produced by two amplifying transistors d313 . i saw circuits on the net which only use ic with out amplyfying goes to the power fet gates . as fet are controlled by volts i think if i connect dircet ic out put to the gates of fet thd will be less . am i right???????????????
and how i can check if a fet will work fine at specific gate voltage .for irf3710 i saw data sheet its gate to source volt is +-22 is that volts required to flly on this fet or some thing else.
how i can convert this ups into modified sine wave ups ????????
how some body will understand my problem and help me to solve this problem . thanks.
  #2
Old 07-30-2008, 12:54 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
The motor of your fan won't run off a square wave.
You might have much better luck using PWM on your input instead of the cd4047, You could then filteri the MOSFET o/p, to get a sine wave.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
Tags
Related Site Pages
Section Title
Worksheet Boolean algebra
Worksheet CMOS logic gates
Worksheet TTL logic gates
Worksheet Opamp oscillator circuits
Worksheet Design Project: audio media-based signal generator
Worksheet Performance-based assessments for semiconductor circuit competencies
Worksheet Mixed-frequency signals
Video Lecture Sine Wave Characteristics - Alternating Current
Textbook Measurements of AC magnitude : Basic Ac Theory
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
