All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-26-2008, 10:22 AM
pipefitter pipefitter is offline
Default Cap start Cap run Compressor
Hi everyone. I have been to this site many times for Excellent advice and info. I have a question on a 230v single phase ac compressor. The compressor is a Copeland CR33KQTFD cap start cap run motor with a potential relay. The original compressor went bad and we ordered a replacement with both caps and the potential relay,well they only sent the compressor and the start cap. The local supply house had the run cap but not the OEM relay. They gave us a generic replacement rated for 110-277 coil volts. After a day of running the relay went bad. We went to another supply house and they crossed the OEM part to a Mars replacement wich is rated for 390 cont coil volts. After the relay was changed we checked the voltage between common and run we had 230v between common and start we had 330v. I know you will have a higher voltage on the start winding but does this seem correct? Thanks in advance Tim
  #2
Old 07-26-2008, 12:06 PM
Default
After a little more research I fount the answer
http://books.google.com/books?pg=PA297&lpg=PA297&dq=higher+voltage+on+the+ start+winding&sig=QZCMmLxS__FZernxwjwhE9v5HIo&ct=r esult&id=tH6KC75vqSwC&ots=l1UXgfsZ2i
Tags
Related Site Pages
Section Title
Worksheet Electromechanical relay logic
Textbook Tesla polyphase induction motors : Ac Motors
Worksheet Mutual inductance
Worksheet DC generator theory
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook Programmable logic controllers : Ladder Logic
Textbook Motor control circuits : Ladder Logic
Textbook Time-delay relays : Electromechanical Relays
Textbook Relay construction : Electromechanical Relays
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bad run capacitor or ? chvyfan General Electronics Chat 15 07-21-2008 09:43 PM
Blowing motor start capacitors jrappl General Electronics Chat 9 11-19-2007 11:35 PM
Cap start motor McKesson General Electronics Chat 3 06-29-2007 03:15 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
