All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-23-2008, 01:17 AM
BWHH BWHH is offline
Default Constant to Momentary Relay PC Applications
Hi All,
I'm looking to build a simple circuit that would take a contstant 12v feed and momentarily trip a relay.
The plan is to use this:
http://www.newegg.com/Product/Produc...82E16811994010
To turn a PC on and off, but the trigger on the PC only needs the power switch to be closed momentarily.
Any ideas?
Thanks for the help!
  #2
Old 07-23-2008, 02:25 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
If a PC is plugged in, there is a 5V source that's always available.
Check out the specifications for the power supply in your PC by form factor.
There is really no need for an external supply.
But perhaps there is. You need to give more details.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #3
Old 07-23-2008, 04:10 PM
Default
What I want to do is power up a PC using the remote control. The problem is, a power switch on a PC is momentary.
This would be independent of the system's PSU. All I'm really trying to do is replace the simple momentary power switch on the PC with a remote control. With the remote I've linked, I would need a way to take its 12v output to trip a relay, but the relay would need to disengage in a second or two max.
  #4
Old 01-23-2009, 04:47 AM
rezmax rezmax is offline
Default Momentary switch
http://www.mp3car.com/vbulletin/user...rn-module.html
This will solve your problem.
Also,
http://www.the12volt.com/relays/page5.asp#ctm
  #5
Old 08-04-2009, 11:30 PM
p_circuit p_circuit is offline
Default Constant to memory_circuit diagram
The diagram shows that the capacitor is installed between the ignition switch a nd the ground> Is this correct?
Is that a standard automotive relay?> I though you need a 2 way coild relay for the momentary function to work.
Does the value of the resistor matter in relation to the cap?
Is the resistor installed on the ground end of the relay?
Does the resistor bring the capacitor back to 0v after the ignition source is switched off?
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Latch circuits
Worksheet Electromechanical relay logic
Worksheet CMOS logic gates
Worksheet Bipolar junction transistors as switches
Worksheet AC motor control circuits
Textbook Monostable multivibrators : Multivibrators
Textbook Fail-safe design : Ladder Logic
Textbook Motor control circuits : Ladder Logic
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
simple programmable relay question dmaxben The Projects Forum 5 04-08-2009 09:56 AM
Relay + MP3 Player + lights project airforce1j The Projects Forum 1 06-25-2008 06:10 PM
latching momentary switch to relay circuit dmc0162 The Projects Forum 3 05-04-2008 06:04 AM
EFI Fuel Relay Problem akajee The Projects Forum 4 01-26-2008 08:18 PM
Need constant on, momentary, AND OFF! Avalanche Breakdown The Projects Forum 7 05-03-2007 04:18 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
