All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-18-2008, 10:06 AM
kram.nacnud kram.nacnud is offline
Exclamation Effects of leading power factor
In a 3 phase system the municipality will measure & bill on the kVA reading, irrespective of the power factor.
In a typical system the power factor is lagging and as such the customer must install power factor correction to reduce cost.
What happens in a case where the power factor is leading? Will the power meter be able to compensate for this and in effect reduce the cost?
  #2
Old 07-18-2008, 10:40 AM
mik3's Avatar
mik3 mik3 is offline
Default
No, it wont reduce the cost. You have to install a power factor correction device for leading power factor if your current power factor correction device is not able to do that.
  #3
Old 07-18-2008, 01:57 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
Actually, many power companies will charge more if the power factor is below a standard minimum value.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #4
Old 11-10-2009, 03:39 AM
foolios foolios is offline
Default
Quote:
Can you explain why this is so?
I've heard of how power companies are thinking about charging residential customers for reactive loads because the times have changed.
What does this all mean?
How does a poor power factor cause there to be more cost? I've heard something about heating up the lines because of inductance, but how does this all play into costing the user more money?
  #5
Old 11-10-2009, 06:38 AM
KL7AJ KL7AJ is offline
E-book Developer
Default
For large industrial customers, a highly reactive load can cause extra stress on transmission components, especially substations. It's not the lone customer, but the cumulative efffect of a lot of low-power-factor customers that make things hard on equipment...even though the actual power consumptions is less. In generaly, most transmission facilities are optimized for maximum efficiency at around 90% power factor.
Eric
__________________
REAL men don't need voltmeters.
Tags
Related Site Pages
Section Title
Worksheet AC network analysis
Textbook Tesla polyphase induction motors : Ac Motors
Worksheet AC power
Worksheet Passive filter circuits
Textbook Synchronous condenser : Ac Motors
Textbook AC bridge circuits : Ac Metering Circuits
Worksheet Time constant circuits
Textbook Practical power factor correction : Power Factor
Textbook Calculating power factor : Power Factor
Textbook Single-phase power systems : Polyphase Ac Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
leading or lagging power factor fancy102 The Projects Forum 9 01-07-2010 08:56 AM
Leading Power Factor And Electronics Grendel General Electronics Chat 0 06-01-2008 10:03 PM
Lagging or Leading Power Factor ha4nguyen Homework Help 4 03-06-2008 05:49 PM
about power factor papa Homework Help 4 11-29-2007 03:26 PM
why do industries want to keep their power factor nearest to one? Faheem Khan General Electronics Chat 3 06-07-2007 06:57 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
