This is my first post.
What is the likely solution to the attached problem. Appreciate your assistance.
Isn't that a dependent voltage source in the southwest loop dependent on the voltage across the 2 ohm resistor in the northeast loop? If so, we have to know how to connect the voltage sense leads across the 2 ohm resistor.Sorry Ratch, partly my fault, there are no voltage sources in this circuit, only current sources.
Since this particular problem in not in any of the books on circuit analysis I have, they do not help me.Ratch, please check your textbook on circuit analysis.
True, but irrelevant. There is a voltage across resistor VX, and I have to know how it is measured before analysis can begin. Look at this voltage controlled current source and notice how the voltage leads are labeled. http://www.freeda.org/doc/elements/vccs.pdf That is the way the resistor VX should be marked. RatchI said in post 12 and I will say again.
There are no voltages sources, dependant or independent in this circuit.
by Jake Hertz
by Jeff Child
by Aaron Carman
by Jake Hertz
