I have a non-working torchiere lamp. As far as I know the halogen bulb is okay, so I assume there is a fault either with the bulb connectors (contacts) or the switch.
I have a simple 'continuity tester.' Is it safe to use that (to check the bulb connectors) with the lamp 'on'?
I'm a novice with electricity and mainly want to make sure I don't electrocute myself.
(Actually, I guess if I can safely test the bulb connectors and those seem okay, I can just conclude from that that the fault is in the switch. But I assume that to do that, the power has to be on?)
Thanks. Replies appreciated.
*** What is a safe way to test the circuit at both sites (i.e., at the bulb connections and at the switch)? ***
