All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Closed Thread   Post New Thread
Thread Tools Display Modes
  #1
Old 07-09-2008, 09:16 AM
studiot's Avatar
studiot studiot is online now
E-book Developer
Default Electronics Tips and Tricks Thread
It has occurred to me that a thread where posters could pass on useful tips, tricks, rules-of-thumb, and conventions that may be of use for when you need a 'how to answer' not an in depth understanding. Please don't use this thread for asking questions.
I will kick off with a very simple but useful formula for making a non standard resistor by adding a parallel resistor to a standard one.
is the required shunt resistor
is the desired non preferred value
is the (next) higher preferred value
The Following 2 Users Say Thank You to studiot For This Useful Post:
nepdeep (11-13-2012), Niharika narayan (05-25-2012)
  #2
Old 07-09-2008, 09:50 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
In retaliation for StudioT's post...
1) Series_ParallelResistanceCalculator.zip - contains an Excel spreadsheet that has StudioT's formula in it, and also does series of lookups on standard E6 thru E192 series resistance tables to ensure use of only the standard values in the results. Just put in the resistance you want where indicated, and resistor combinations for all E-series are displayed.
2) E24PLL.ZIP - contains E24PLL.TXT, a rather large (224kb) text file that you can scroll through to find pairs of resistors to use in parallel to obtain a particular resistance.
Here's a handy web page that does both series and parallel calculations for you, for E12 and E24 series resistors:
http://www.qsl.net/in3otd/parallr.html
Note that you must select E12 or E24 each time you enter a new value, or you will receive an error message.
[eta]
3) CapSMTMarkings is an excerpt from a KEMET Packaging and Marking document, for identification of SMT capacitor values.
If there are two letters and a number, the manufacturer is the first letter. If just a letter and a number, only the value and multiplier is specified.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
The Following 8 Users Say Thank You to SgtWookie For This Useful Post:
ahillelt (06-08-2013), Anal0g1nBlack (01-26-2011), mwmorgan (05-07-2013), nepdeep (11-13-2012), Niharika narayan (05-25-2012), PackratKing (08-16-2010), PGB1 (02-01-2013), Zanac-X (06-27-2012)
  #3
Old 07-10-2008, 05:07 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
Rule of thumb for calculating power supply filter capacitors:
C = 0.7(I)/ΔE(f)
Where I = load current, ΔE = acceptable ripple voltage, and f = pulses per second from the rectifier.
For full wave rectified 60Hz, this works out to:
C = 0.00583 * I / ΔE
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
The Following User Says Thank You to thingmaker3 For This Useful Post:
PackratKing (03-11-2013)
  #4
Old 07-10-2008, 07:46 AM
miconos miconos is offline
Default RFIC inductance calculation
Rule of thumb for RFIC inductance calculation:
1mm ~ 1nH
The Following 2 Users Say Thank You to miconos For This Useful Post:
nepdeep (11-13-2012), PGB1 (02-01-2013)
  #5
Old 08-16-2008, 12:09 AM
yubyub yubyub is offline
Junior Member
Default
Tip: check things more than once when soldering a big project. (i just soldered 50 transistors backwards)
The Following 3 Users Say Thank You to yubyub For This Useful Post:
nepdeep (11-13-2012), richiechen (01-12-2012), vishnu.mec (04-09-2012)
  #6
Old 11-04-2008, 07:36 PM
KL7AJ KL7AJ is offline
E-book Developer
Default
If any of you can get a copy of the November 2008 QST, I have an article in Technical Correspondence called "Making the Glass Half Full." I discuss in detail the reciprocal impedance parameters: conductance, susceptance, and admittance. These GREATLY simplify otherwise daunting parallel impedance problems.
73,
Eric
__________________
REAL men don't need voltmeters.
The Following User Says Thank You to KL7AJ For This Useful Post:
pabonbd71 (10-29-2012)
  #7
Old 12-18-2008, 01:15 PM
eblc1388's Avatar
eblc1388 eblc1388 is offline
Default
If your 9V battery connection is too short for the power supply, why not try the following and kill your project.
You won't need to power it up anymore.
__________________
L.Chung
  #8
Old 01-14-2009, 12:47 AM
electratech electratech is offline
Junior Member
Default VIP chart
VIP chart for quick guide
The Following 6 Users Say Thank You to electratech For This Useful Post:
ElectroDFW (10-04-2011), Manticorp (11-13-2012), netwillie (08-29-2010), PackratKing (08-16-2010), RJ2 (08-11-2010), wayne2056 (03-09-2011)
  #9
Old 01-30-2009, 03:09 PM
Skeebopstop Skeebopstop is offline
Send a message via Skype™ to Skeebopstop
Default
Remember the skin effect. When trying to rid yourself of EMI, don't try to run it out of your system on a regular wire, rather ensure the wire has a large surface area (i.e. shielding).
  #10
Old 01-30-2009, 06:32 PM
leftyretro's Avatar
leftyretro leftyretro is offline
Default
When designing power supplies be sure to size the input protection fuse so that the equipment being power blows up first so as to protect the power supply fuse from blowing open first.
Lefty
__________________
Measurement changes behaviour
Tags
Related Site Pages
Section Title
Worksheet Trigonometry for AC circuits
Worksheet Capacitors
Textbook How voltage, current, and resistance relate : Ohm's Law
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need tips on the Teknikit console 92-300 tdavis.unk General Electronics Chat 1 02-05-2006 01:36 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
