All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-04-2008, 02:41 PM
andyqd andyqd is offline
Default How do I connect 1watt or 3 watt LED
How do I connect 1 watt or 3 watt LED or higher on a 14v source (in my car).....I know that you can connect a low power LED(5 mm) using a resistor....but a high power LED like 1watt onward....you need a driver for it...is that necessary? why cant i just connect a Resistor by itself? ....how can i design a driver that can handle....LED @ 200mA, Vf: 3.6 - 4.2....power source: 12-14 Volt
  #2
Old 07-04-2008, 02:56 PM
beenthere's Avatar
beenthere beenthere is offline
Default
If you want to use a fixed resistor, figure it like you would for any LED - the voltage driving current is what's left after you subtract the LED Vf. That will be on the order of 50 ohms (standard values are 47, 51, and 56 ohms). The fun part is getting the resistor rated for at least 5 watts. If anybody still sells sand resistors, they would be pretty inexpensive (the body is a hollow rectangle of some ceramic. The wire element is inside and sealed in with a gritty composition that looks like sand).
__________________
First comes the hardware, then the software.
  #3
Old 07-04-2008, 03:16 PM
bertus's Avatar
bertus bertus is offline
Administrator
Default
Here are some links to pages with led circuits.
http://www.educypedia.be/electronics/circuitsled.htm
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #4
Old 07-04-2008, 03:48 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
If you use a fixed resistor for limiting current, then you will be wasting more power in the resistor than you will be using in the LED! This is due to Ohm's Law:
P = E * I, where
P = Power in Watts,
E = Voltage,
I = Current in Amperes
There's another problem, and that is the voltage in your vehicles' electrical system may vary widely between the battery being fully discharged (11.4v) to the alternator running at full blast, perhaps as high as 14.5v or even higher.
Let's say that your LED's current is 320mA @ 4v for the moment. That's 1.28 Watts.
Let's figure the vehicle's electrical system will put out a nominal 13.8v.
So, the limiting resistor will be:
Rlimit = (VoltageSupply - Vf(LED)) / I(LED)
Rlimit = (13.8 - 4) / 320mA
Rlimit = 9.8 / 0.32
Rlimit = 30.625
Now we need to calculate the wattage required:
P = EI
P = 9.8 * .32
P = 3.136 Watts
You'll consume 2.45 times as much power in the resistor as the LED. But, that's not all - we don't have REAL current regulation, because what happens when the alternator is trying to recharge a dead battery and is outputting 14.5v?
We're still going with the Vf of 4v, and 320mA is the target current.
14.5V - 4V = 11.5V across Rlimit, let's figure the current through the resistor.
I = E/R
I = 11.5/30.625
I = 375.5mA - oops, you just fried the LED!
So, do the whole series of calculations again for 14.5v. What happens when the ignition is off, and the battery voltage drops to 12.4v or so? The LED gets a lot less current, and is dim. You don't really want that, either.
You could use an LM317 as a constant current regulator. However, it's still a linear regulator, and will dissipate a lot of power (roughly 2.5 times the power used in the LED).
Wasting that power in the resistor or regulator means wasting the fuel that the engine has to burn to generate the electricity.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #5
Old 07-04-2008, 08:18 PM
John Luciani's Avatar
John Luciani John Luciani is offline
Default
Unless you use a switching converter you will be less than 30% efficient.
On-Semi, Maxim, Linear Technology all make switching converter ICs for LED
applications.
(* jcl *)
  #6
Old 07-05-2008, 12:25 AM
Audioguru Audioguru is offline
Banned
Default
Use two LEDs in series and in series with an LM317 current regulator.
Then the LEDs work perfectly and the LM317 does not waste much power.
  #7
Old 02-05-2010, 01:13 PM
conntaxman conntaxman is offline
Junior Member
Default
Audio; as you told the other person to hook the leds in series,Do you know of a cir. that would run 8 [3watt//FV=3.5 Current =700ma.Supply voltage =12vdc] I dont think that I could run all those in series. And I have been looking all over the net and asking around for a small cir. to run these.
Tks
John
  #8
Old 02-05-2010, 01:27 PM
cjdelphi cjdelphi is offline
Banned
Default
Quote:
Originally Posted by SgtWookie View Post
If you use a fixed resistor for limiting current, You'll consume 2.45 times as much power in the resistor as the LED. But, that's not all - we don't have REAL current regulation, because what happens when the alternator is trying to recharge a dead battery and is outputting 14.5v?
I = E/R
I = 11.5/30.625
for almost all high powered LED's 375 vs 320 is just an extra little tickle as most LED's.. XP-RE and the XPG range from cree all handle 1amp of current, it's the heat you have to worry about....
So a 5watt 30 ohm resistor unregulated from the car would be easy, and if one day your car's alternator produced more voltages and did lead to current > 1amp then... well
the LED will be the last thing to be concerned about, i'd be worried about the battery / car electronics exploding
  #9
Old 02-05-2010, 03:29 PM
Banned
Default
Quote:
Tks
John
Eight 3W LEDs use 24W. If they are in series then you need 28V plus a few volts for the current regulator.
I have not seen a simple circuit that can stepup 12V to 31V at such a high power but maybe somebody designed one.
  #10
Old 03-04-2010, 06:41 PM
Junior Member
Default led
Quote:
,Here is a link for you to connect a hp.led. to 14vdc,and their are other on DIY.
http://www.instructables.com/id/Supe...er-LED-driver/
Tags
Related Site Pages
Section Title
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
LED Replacement light bulbs Sparky General Electronics Chat 21 10-21-2008 06:14 AM
Photodetector to LED robby991 General Electronics Chat 17 05-21-2008 09:40 PM
LED short of forward voltage Pootworm General Electronics Chat 5 10-28-2007 12:58 PM
12/24V Incandescent Light Bulb Dimmer to drive MR-16 LED Lamp monkey19939 The Projects Forum 5 07-25-2007 12:46 AM
LED Dimming in Parallel pfhorge The Projects Forum 6 02-27-2007 07:36 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
