All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-30-2008, 04:21 PM
rvb53 rvb53 is offline
Junior Member
Default Phase Angle between voltage and current
hi everyone,
I need to know that by calculating phase between volatge and current.....
what information does the phase angle can give.........?
like voltage or current lagging or leading, inductance....etc? but I need to know more....?
  #2
Old 06-30-2008, 05:04 PM
silvrstring silvrstring is offline
Default
rvb53,
When your circuit's current phase angle is leading, your circuit is capacitive. If your current phase angle is lagging, the circuit is inductive.
What this means is if you were to draw the Thevenin equivalent of the circuit, you would have an inductor OR a capacitor--not both.
If it is application you are looking for, this will reveal its importance when you want to adjust a circuit to be more efficient concerning power and current. Often, an example circuit will point out the waste of power that can happen when a circuit is too inductive--VAR(inductive). You will use a capacitor to balance the reactive power your circuit is using, and try to bring reactive power as close to zero as you reasonably can, so that only real power is used--minimizing power loss/waste.
You might want to read more about power factor if you are interested in applications.
Hope this helps.
  #3
Old 06-30-2008, 11:40 PM
Sparky Sparky is offline
Member
Default
You might look at this for an explanation
http://www.allaboutcircuits.com/vol_2/chpt_1/5.html
and surf some of the other "Volume II AC Circuits material" at http://www.allaboutcircuits.com/vol_2/index.html
  #4
Old 07-01-2008, 04:32 AM
CDRIVE's Avatar
CDRIVE CDRIVE is offline
Default
Quote:
Originally Posted by silvrstring View Post
rvb53,
Actually, that statement is a bit misleading. Since a purely reactive circuit consumes no power at all. Phrased more precisely, phase angle is brought as close to zero as possible to insure that all available power will be delivered to the load.
  #5
Old 07-01-2008, 02:44 PM
Junior Member
Default
hi everyone,
thanx for ur suggestions...
I need more information that phase angle infer to ,other than above all...
  #6
Old 07-01-2008, 09:28 PM
CDRIVE's Avatar
Default
Quote:
Do you have a good grasp of Ohms Law? If you do we can take it from there. By the way, don't feel bad about not fully grasping this subject. I've been a professional in this industry since 1966 and I remember vividly when phase angle was first introduced to me and how confused I was!
  #7
Old 07-01-2008, 10:05 PM
theamber's Avatar
theamber theamber is offline
Default
Current is the only quantity here and voltage is just a potencial diference. Look in the time axis.
Although both the current and the voltage oscillate sinusoidally in an AC circuit they will not necessarily rise and fall simultaneously with each other in each circuit element or the circuit as a whole. The current and voltage will oscillate with the same frequency but they will (in general) be out of phase with each other. The exception being when the circuit is in resonace (phase angle of the circuit is 0) or if there is only resistors in the circuit.
In a pure inductor, the current lags the voltage by 90 degrees so if you look at the two wave forms (voltage and current) you will see the voltage at maximum at the same time the current is zero. As you introduce resistance into the circuit, the current lags by less.
In a capacitive circuit the current is said to lead the voltage although the reality is slightly different because a current happening before a voltage is applied is crazy. The truth is a negative current lagging by 90 degrees but the current leading idea works because the waves continue repeating.
Both reactances offer opositions to changes in voltage or current that is why always one lags the other.
It is useful to think of the phase angle as the angle by which the peak voltage leads or lags the current. If the phase angle is positive the voltage leads the current (inductive) by offering oposition to current changes. The oposite happens with a pure capacitive circuit. In a pure inductive or capacitive circuit the power dissipative is 0 but that never happens in the real world with all the variants.
I hope you get it. At least this is the way I understand it.
  #8
Old 07-02-2008, 07:18 PM
Junior Member
Default
hi everyone,
thanx for ur information and suggestions....
  #9
Old 07-02-2008, 07:37 PM
arrie's Avatar
arrie arrie is offline
Default
This subject can be really confusing. What you need to keep in mind, when talking about current leading or lagging and phase angles, you are working with alternating current. The magnitudes of voltage and current varies continually, and this variation takes the form of a sine wave.
As soon as you hear sine wave you hear trigonometry, good luck. The different components have different effects on the phase between voltage and current, because of their characteristics, some has to charge up, other produce opposite potential, etc. except the resistor, it basically chucks your current in the form of heat.
If you think of a sine wave, it varies, say it starts at 0, increases to a max, then decreases to a zero and through into a negative value and finally back to zero.
So somewhere you will have no current at all, elsewhere it will be at maximum, and elsewhere a negative current, meaning the polarity has reversed, this can be e.g. because the inductor is now driving your circuit, etc. There are many other scenarios depending on what the circuit looks like, and at what point in the circuit you are looking into it.
Go find some good books: Hughes electrical and electronic technology, Delmars textbook of electricity, there is thousands.
good luck
Tags
Related Site Pages
Section Title
Worksheet AC power
Worksheet Impedance
Worksheet Capacitive reactance
Worksheet Inductive reactance
Textbook Power in resistive and reactive AC circuits : Power Factor
Textbook Calculating power factor : Power Factor
Textbook Series resistor-capacitor circuits : Reactance And Impedance -- Capacitive
Textbook AC capacitor circuits : Reactance And Impedance -- Capacitive
Textbook AC inductor circuits : Reactance And Impedance -- Inductive
Textbook Series resistor-inductor circuits : Reactance And Impedance -- Inductive
Similar Threads
Thread Thread Starter Forum Replies Last Post
Electric motor loads; regulating voltage AND current Tenacious Techhunter General Electronics Chat 16 12-21-2008 12:11 AM
To calculate Phase angle or phase difference between voltage & current. rvb53 Homework Help 11 06-17-2008 04:13 PM
waveforms capacitor voltage / current kk57 General Electronics Chat 4 10-25-2007 08:51 PM
Power Engineering Help (Star-Delta) mksa Homework Help 2 05-09-2006 05:41 AM
fields alphaone Physics 4 12-23-2005 06:03 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
