All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-23-2008, 06:01 PM
masterdcj masterdcj is offline
Lightbulb Project: Object Counter
Hey, am making a project which senses an object passing through a gate and counts the number (and displays it). For that i am using a 4-bit ripple counter IC (74LS293). I am displaying with 7-segment display.
How can i drive two 7-segments using a single 7448 decoder?
  #2
Old 06-23-2008, 09:24 PM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
Can you supply us with a schematic diagram of your circuit at this point?
hgmjr
  #3
Old 06-24-2008, 12:02 AM
beenthere's Avatar
beenthere beenthere is offline
Default
You should be able to multiplex the 7448. I'm amazed you have one. Original TTL IC's are hard to come by.
Multiplexing is lots more trouble than just using another BCD-to-seven segment decoder.
__________________
First comes the hardware, then the software.
  #4
Old 06-24-2008, 04:49 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
See the attached schematic. I drew this up quite a while ago when I was building a coil winder, to keep track of the number of turns; it wasn't really meant for general publication or it would be more neat. It uses a Hall-effect device that senses when the shaft of the winder makes a complete turn.
But of interest to you is the use of the CMOS 4553 and 4543 devices; one is a 3-digit BCD counter/mux, the other is the BCD to 7-segment driver. Pretty handy pair of CMOS IC's, and you can get them just about anywhere still. This just gives you a general idea on how to hook them up to drive three 7-segment LEDs.
Note that Vdd and ground pins are not shown, nor are the 0.1uF bypass caps.
Note that the 7-segment displays are common anode.
Where on earth did you find the 7448?
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #5
Old 09-01-2008, 06:57 PM
damilola damilola is offline
Default
tell me all i need to know about a two digit counter which senses an object passing through a gate and counts the number (and displays it).
  #6
Old 09-01-2008, 07:11 PM
SgtWookie's Avatar
Expert Member
Default
Quote:
See the circuit I posted?
Use it.
__________________
General info:
  #7
Old 09-06-2008, 06:53 PM
navid444's Avatar
navid444 navid444 is offline
Default
can u post the program used
  #8
Old 09-06-2008, 07:01 PM
SgtWookie's Avatar
Expert Member
Default
Quote:
The program that I used to create the schematic is Cadsoft DE's Eagle Layout Editor.
You can download the current freeware version from Cadsoft's website:
http://www.cadsoft.de/
The freeware version is limited to single-page schematics, two layers in a board, and the size of the board is limited to about 3"x4". It is still quite useful, even with those limitations.
It is confusing at first. Going through the tutorial is highly recommended.
Here is another tutorial:
http://www.sparkfun.com/commerce/tut...&sipp=1&page=8
You may actually wish to start with this one.
__________________
General info:
  #9
Old 09-06-2008, 07:06 PM
hgmjr's Avatar
Super Moderator
Default
If you are referring to the use of a program for the circuit, You do realize that the circuit does not use a microcontroller, right?
hgmjr
  #10
Old 09-06-2008, 07:29 PM
SgtWookie's Avatar
Expert Member
Default
From a PM:
Hi
i m the mechatronics student n goning to start my final year project can u give me some projects.
mail me plz at this id
(E-mail address omitted)
Navid,
I seldom help people via PM, particularly if they are new.
1) This defeats the purpose of the board, by not sharing information with other viewers.
2) This eliminates responses from other qualified individuals that you may otherwise have received.
3) It fills up my PM box, which fills up rapidly enough.
4) I don't generally use E-mail for replies either, as this would wind up consuming all of my free time. If you wish to be notified via Email of replies to your thread, you can "Subscribe to this Thread" under the "Thread Tools" drop-down list.
You and the community are best served by starting a new thread in an appropriate forum. If you are not certain WHERE to post, start your thread in the General Electronics Chat by opening that forum, and clicking the "New Thread" icon. If a different forum would be more appropriate, a Moderator will move your thread there.
__________________
General info:
Tags
Related Site Pages
Section Title
Worksheet Counters
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to post a project to the collection Dave The Completed Projects Collection 1 01-30-2013 08:15 PM
Designing a 3-bit counter with D flip flops Mearyk81 Homework Help 4 05-31-2008 10:44 PM
Object Counter Circuit extremeads1 The Projects Forum 6 07-27-2007 03:21 AM
synthesisable verilog for frequency counter ljmmus The Projects Forum 1 03-13-2007 09:47 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
