I'm currently working on a synthesizer using 74153 4 to 1 line data selectors. I had been using CMOS 74153s, but I fried a couple of them, and all I am left with is TTL. The TTL chips dont seem to work at all, I plug them in and they just give me 0 on the output with all 4 input terminals set to 5v. I figure since this happens with every TTL chip that I have, I must be doing something wrong.
Is there a special way I should hook up the TTL chips in order to get them to work correctly? I was thinking maybe capacitors across the Vcc and Gnd to reduce noise from the source, but I really have no idea.
