All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-18-2005, 07:37 AM
e1291426 e1291426 is offline
Default
Hi,i am an electronics engineering student,and i need a dc to dc converter circuit design without transformer and op-amp,i mean only using transistors for amplification with the specifications:input:5v; output:6v minimum;power:supply a power of at least 200mw;input voltage tolerance:5v+5%; output tolerance:should be in the range of Voutput+5%.Please help me in a few days :
  #2
Old 05-18-2005, 06:55 PM
Brandon Brandon is offline
Default
Quote:
Originally posted by e1291426@May 18 2005, 02:37 AM
Hi,i am an electronics engineering student,and i need a dc to dc converter circuit design without transformer with the specifications:input:5v; output:6v minimum;power:supply a power of at least 200mw;input voltage tolerance:5v+5%; output tolerance:should be in the range of Voutput+5%.Please help me in a few days :
Hmm... only way to step up the voltage w/o using a transformer is with an inductor.
You could very easily use the 5v input to trigger a 555 timer tuned to a lower harmonic of the Class C oscilation freq and just rectify the output. Since you have 5vac source, you could get 10vac output on the Class C. Rectify and throw a 6v Zener and ur good to go.
All this is fairly simple to design and build. You can google alot of this, but yo should be able to find Class Cs in your electronics book.
  #3
Old 05-18-2005, 10:05 PM
pebe pebe is offline
Default
This link gives a step-up convertor from 5v to over 13v. You could probably get down to 6V by changing the feedback pot.
http://www.interq.or.jp/japan/se-inoue/e_ckt232.htm
Tags
Related Site Pages
Section Title
Worksheet Linear computational circuitry
Worksheet Power conversion circuits
Worksheet Basic AC-DC power supplies
Worksheet Advanced electromagnetism and electromagnetic induction
Worksheet Impedance matching with transformers
Worksheet Step-up, step-down, and isolation transformers
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Textbook Electrical isolation : Transformers
Textbook Special transformers and applications : Transformers
Textbook Input and output coupling : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
bidirectional dc dc converter adamhill178 General Electronics Chat 0 05-01-2014 02:30 AM
Researching the history/compatibility of 120v DC/AC utility power DMahalko General Electronics Chat 70 07-04-2012 06:14 PM
Confused about transformer saturation daviddeakin General Electronics Chat 49 06-26-2012 07:19 PM
smoothing dc transformer ? Mathematics! General Electronics Chat 23 11-23-2009 10:12 PM
Full-Wave Bridge Rectifier Filter + Regulator DC Power supply Petrucciowns Homework Help 52 07-10-2009 05:30 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
